Airbag suspension???
Old Nov 25, 2007 | 02:12 PM
Marks69BB's Avatar
Marks69BB
Default Airbag suspension???
Anyone used these on the front or rear of a vette?
Old Nov 25, 2007 | 06:53 PM
Z-man's Avatar
Z-man
From what I've read, I'd love to give it a shot. Need a few more bucks though, and I'll wait until I have the body off the frame. I wonder where the best place to put the pump and tank would be? Near the gas tank?
Old Nov 25, 2007 | 07:41 PM
Durango_Boy's Avatar
Durango_Boy
Yep, seen a guy here the last few months with air bags.
http://forums.corvetteforum.com/member.php?u=254007
He has posted a lot of pics of his Vette suspension, so looking for posts using his name int he advanced search will get you lots of results.
Old Nov 25, 2007 | 08:45 PM
ShinodaVette's Avatar
ShinodaVette
I'd like to have airbag suspension on mine. If I had seen the bolt-in kits for C3s before I bought all my suspension that's probably what would be on there. I'm not changing it now though.
Old Nov 25, 2007 | 11:36 PM
Marks69BB's Avatar
Marks69BB
Thanks for the replies!
Any websites or sources for these kits you mention?
Old Nov 26, 2007 | 12:12 AM
onaqwst's Avatar
onaqwst
i've been wanting to do this for 3 years..... since i have my tank/2 compressors/switches and wires...all i need are the bags and air lines.....
you need to replace the rear leaf with a fabbed moment arm setup....
i'm still not sure what size bags i need though..... i would think the same on all 4 corners..... i might have a friend help me bag mine when the time comes.... i still need to draft up the rear end setup and have his shop make it up for me........
i'm gonna mount the tank where the spare tire used to be....but first put up a plate of aluminum under the gas tank just to be safe a bit.....
b
onaqwst's Avatar
onaqwst
that link above, that guy has hydrolics and not air ride....fyi
b
Old Nov 26, 2007 | 09:35 AM
Taijutsu's Avatar
Taijutsu
Default Like the stance!
Onaquest: What size tires/wheels do you have and how much drop did you use? TIA
Ricisan
Old Nov 26, 2007 | 10:24 AM
Durango_Boy
b
Whoops. My bad. Big difference...sorry.
Old Nov 26, 2007 | 02:24 PM
enkeivette's Avatar
enkeivette
b
Phhh... it's all bling, there's no difference.
Old Nov 26, 2007 | 03:06 PM
onaqwst's Avatar
onaqwst
Ricisan
they are 20"x9" cabo 728 with 45 series tires
4.5" backspace/0 offset
stock t-arms
overall diameter is about .5" larger than stock
no rubbing
i dropped the front about 1.5" ...i cut 1 coil off the front springs
b
Old Nov 27, 2007 | 06:09 PM
ShinodaVette
I thought these guys already had a C3 kit but it looks like its not available yet. http://www.sterlingaccessories.com/
Old Dec 2, 2007 | 12:03 AM
Russ427's Avatar
Russ427
Cruising
I built a rear system with the Shockwave 7000s. The air ride was nice enough and I even went so far as to mount the 5 gallon air tank in the back. I swapped back to the QA1 double adjustable coil-overs with 110# springs but I wished I had bought some Bilstein shocks to try before I did. I just haven't had time to fool around with it anymore.
To Airbag suspension???
