Oil Pressure?
Old Nov 30, 2007 | 10:08 AM
gbags's Avatar
gbags
Default Oil Pressure?
78' stock 350 140k plus miles ???? (I think) What pressure should the gauge read if working properly?
Old Nov 30, 2007 | 10:15 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
My '76 runs at around 40 on the highway and 35 or so at idle. This original engine has 92k on it.
Old Nov 30, 2007 | 10:25 AM
Durango_Boy's Avatar
Durango_Boy
My engine still has really good bearing tolerances so I have 40-70 idle to cruise oil pressure using 10-30.
OP -
With a lot more wear, like on a high mileage engine, those numbers will be somewhat diminished. Maybe half???
What are your readings when hot at both idle and cruise?
If it is a bit low for you, consider a heavier weight oil.
Old Nov 30, 2007 | 10:32 AM
Jud Chapin's Avatar
Jud Chapin
I bought the car new and I don't think the pressure has changed at all except when I changed to Mobil 1 where it now runs a slight bit higher. Again, mine runs at about 35 at idle and 40 at cruise when fully warmed up. I've never touched the engine other than to replace gaskets.
Old Nov 30, 2007 | 11:14 AM
79L48's Avatar
79L48
79 L48 original with 80K runs 40 cruise, 25 idle hot.
Old Nov 30, 2007 | 05:57 PM
stock76's Avatar
stock76
76 L-48 118.000 original miles. Mobil1 20w50 full synthetic. 40psi cruising, 25-30psi at hot idle.
Old Nov 30, 2007 | 08:39 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Ideally, you want 10psi per 1000rpm, hot. So, you're looking for 30# at 3000, 40# at 4000, and so on. A little more at hot idle is fine, but you certainly don't want to be seeing anything near 50# then. If you're below that 10/1000, try a heavier viscosity and see if that does the trick. Just be sure to watch your pressures during seasonal changes.
Old Dec 1, 2007 | 11:59 PM
birdsmith's Avatar
birdsmith
Understand that (unlike a Ford) small Chevys take their oil pressure tap from the upper aft end of the block which is the last place to recieve oil. A 15-20 psi reading at idle is nothing to be concerned about, since it's already past the crank and cam by the time it produces a reading at the gauge.
Old Dec 2, 2007 | 01:15 AM
Aggitated Monkey's Avatar
Aggitated Monkey
My '80 has 96K and run at 40 and idels around 35 with 10-40.
To Oil Pressure?
