Edelbrock Choke connection
Old Nov 27, 2007 | 09:26 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Edelbrock Choke connection
Where did you guys hook up your Edelbrock choke wire? This is for a 68.
Old Nov 27, 2007 | 09:48 AM
lars's Avatar
lars
You can do one of 2 things: Either hook it up to the windshield wiper motor (always hot when ignition is on) or you can run it through the firewall and hook it up to the "ACC" or "IGN" terminal of your fuseblock. Just don't run it off the coil wire.
Old Nov 27, 2007 | 05:28 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Thanks Mr. Lars.
Old Nov 27, 2007 | 06:25 PM
neuroclast's Avatar
neuroclast
I know this is kinda a weird question. But what exactly does the choke DO? It doesn't seem to make my car start any easier, it damn well doesn't hold an idle at cold without me help any easier, so what's the purpose?
(I can control mine via a switch, so I've tested both ways, thats why I'ma askin')
Old Nov 27, 2007 | 10:32 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Sounds like an adjustment issue.
When you get ready to start your vette do you depress the pedal all the way to the floor? That will reset the choke, closes it and sets the idle speed cam (if you have one). Pumping the gas before the start helps sometime too.
Old Nov 30, 2007 | 02:43 PM
neuroclast's Avatar
neuroclast
Doesn't seem to do anything either way. I have it setup now to come on with power, and I don't really notice it doing anything. What's it supposed to do anyway?
Old Dec 1, 2007 | 09:38 AM
lars's Avatar
lars
The choke richens the mixture on a cold engine from 14.7:1 to about 13:1 by restricting ariflow. The choke and its associated linkage also raises idle speed on the engine when cold. If these things aren't happening, your choke is not set up right. Also, if you engine starts the same without a choke when cold, you're running way too rich - a correctly jetted carb will run lean when cold and will not maintain idle or good drivability until fully warmed up.
You have something set up backwards. An electric choke does not come on with power - it goes off with power.
Old Dec 1, 2007 | 01:12 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
Lars didn't mention it. What happens when you turn your car on, the power to choke starts to heat it up and loosen the coil spring slowly. The slowly opens the choke flap or blade. It's just a little oven.
Old Nov 19, 2012 | 11:28 PM
MikeV1's Avatar
MikeV1
6th Gear
great info thanks!
Old Nov 20, 2012 | 02:12 PM
scottyp99's Avatar
scottyp99
Ideally, you would want to find a power source that goes hot when the engine actually starts, but it can be difficult to find such a power source, especially on older cars that didn't come with an electric choke. The aforementioned power sources will work, but keep in mind that when the ignition key is on ACC, like if you were listening to the radio with the engine off, the choke will be heating up, and will be open if you try to start the car right away. This can burn out the bimetal element that males the choke operate, too, if left on long enough without the engine running. There is a small air draw through the choke housing when the engine is running, caused by manifold vacuum, which is used to keep the element from getting too hot, and also opens the choke flap a little bit once the engine starts, through the use of what is called a pullover valve. An electric choke isn't all that complicated, but there is a little more to it than it may first appear.
Keep the shiny side up!
Scott
Old Nov 20, 2012 | 02:50 PM
BKarol's Avatar
BKarol
I installed an oil pressure switch, two prongs, under the dist. One goes to the wiper hot and the other to the electric choke. In this way current is only sent when there is oil pressure:
Old Nov 20, 2012 | 03:15 PM
Shark Racer's Avatar
Shark Racer
Neat! I should do this for my choke and e-fans.
Old Nov 20, 2012 | 10:00 PM
scottyp99's Avatar
scottyp99
Outstanding, karol!!! Simple and effective! I like it!
Scott
Old Nov 21, 2012 | 10:51 AM
MikeV1's Avatar
MikeV1
6th Gear
Good stuff fellas.....I was able to determine the ING spot on fuse panel is "Hot" when key is in "On" position, with test light to choke connection. I initially put positive wire to "ACC" spot on fuse panel and found it was "Hot""All"the time. Even with car off,key out. It drained my battery......Hence "ACC" spot is not an option on '81
Enjoy the Bird
To Edelbrock Choke connection
