complete motor off ebay
Old Nov 27, 2007 | 06:36 PM
vett 68's Avatar
vett 68
Default complete motor off ebay
has anyone bought a motor off ebay? i'm going to put a 383 in my 68 and the prices I've been getting at local shops are a lot more. Can anyone tell me if you have had success and good luck with using ebay. If you know the names of companies I could check on that would be helpful. The prices through ebay are cheaper but I worry about the condition and internal parts being used, quality etc. If anyone has had a problem with warranty work being done.
Thanks for all input.
Old Nov 27, 2007 | 06:45 PM
Durango_Boy's Avatar
Durango_Boy
The old expression, "You get what you pay for..." comes to mind. The engines bought from reliable engine builders cost what they do based on price and quality of parts, time to assembly and machine, and warranty. I would avoid any REALLY good deals unless you can see it Dyno and read reviews and see warranty details in paper.
There are a lot of quality good deals out there, as a lot of our C3 brethren buy crate motors. I have always had good luck with GM crate motors, give or take some checking of torque specs.
Old Nov 27, 2007 | 06:57 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Cheap crate motors on the internet are...well cheap motors. They might say they have certain parts in them but they might not as one forum member found out. I wouldn't buy one period.
I have been saying this for years and fortunately enough I think people are listening because I don't see any " My crate motor just blew up " threads for some time now.
So either they are going to a quality machine shop near them and getting one built or they are too embarrassed to post that their crate motor just blowed up real good .
Old Nov 28, 2007 | 12:53 AM
Bowerss2's Avatar
Bowerss2
bite bulett and go for a namebrand, even GM performance.
Old Nov 28, 2007 | 03:15 AM
jdb929's Avatar
jdb929
Alot of people like to trash the stuff on e-bay, but it's not all bad. Alot of quality engine builders like Speed-O-Motive are placing engines up for sale on e-bay. Just do your reasearch on the companies and you will find a quality product for a better price than you will typically find locally.
Old Nov 28, 2007 | 10:10 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
This is true, a lot of engines on ebay are from 'known' builders, however, if there is a problem is it easier to work with the machine shop across town or the one across the country? Local, reputable service has value also.
Example - When I built my 396 I used a speed shop recommended, local shop. The master machinist had done a lot of Eagle kits, but had always balanced them himself. When I brought in an Eagle balanced kit for them to install, the master personally checked all aspects of the balance job to verify how well Eagle's job was. Do the ebay guys check such things or just throw them in & assume it's correct?
BTW - The Eagle kit balance was spot on.
Old Nov 28, 2007 | 10:36 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
I have been struggling with this too. I have been thinking hard about getting this motor from and Ebay builder - it SEEMS to be a killer deal. The guy has 52 reviews with 100% positive rating. I emailed hime several times he was responsive - BUT after getting screwed on the car I am VERY hesitant EVEN though this guy seems first rate...
http://cgi.ebay.com/ebaymotors/ws/eB...176945466&rd=1
Old Nov 28, 2007 | 11:14 AM
ratflinger's Avatar
ratflinger
At least his shop pictures show a clean, organized shop. Get a parts list first. Chinese parts are cheap, in many ways. This guy is making money or he'd quit, and yes you can get great prices if you buy pistons a train car at a time, but he's talking big numbers for a small price.
The corner hasn't been cut, it's been completely rounded off!
Old Nov 28, 2007 | 11:33 AM
Wrencher's Avatar
Wrencher
Pretty hard to beat the GM warranty, and there's no shipping.
Hans
Old Nov 28, 2007 | 11:54 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
The parts list is a GREAT TIP!!! I would like to avoid Chinese rings in my new motor. This and the trans swap are pretty much going to take my budget out for a while.
Old Nov 28, 2007 | 03:12 PM
11Jake's Avatar
11Jake
I bought a 350 motor from Phoenixmusclecar on eBay. It was a total piece of ****. Was advertised to have 380hp with 400lb of torque. It was more like 200hp with maybe 250lb or torque. With-in a thousand miles on the motor it blew a headgasket & bent a rod. I pulled the motor and disassembled it to find out it had 305 heads with the absolutely cheapest rods, crank and cam known to man kind. I concluded that I paid $3000 for a nice carb and water pump, which is all that I reused on my new 383 that I built my self. I built my 383 for $5500 with all high quality parts that is estimated to have 490hp with 510lb of torque. You could build yourself a quality 400hp motor for $2500 to $3000 with the motor you have. Do yourself a favor and built it yourself or find a local guy that is reputable. I never did get any of my money back because I installed it after the warranty.
Quote: Getting ripped off across the entire country “priceless”
Old Nov 28, 2007 | 05:57 PM
75 Red Vert's Avatar
75 Red Vert
Hard to beat the GM guarantee & you have someone in your own town to talk to if there are troubles. I'd never put a few $k out for a motor a timezone away from me.
Old Nov 28, 2007 | 06:12 PM
vett 68's Avatar
vett 68
thanks for the reply phoenix was one i was thinking about buying from not know i'll either buy local or build self thanks for help
Old Nov 28, 2007 | 08:43 PM
MotorHead's Avatar
MotorHead
Hope you didn't buy one from them, I personally know a forum member who did, and it blowed up real good
Old Nov 28, 2007 | 09:37 PM
Bullcrappy1's Avatar
Bullcrappy1
YearOne has a 400 hp 350 crate motor for 3000.oo and more then a couple people have used it with great success.
r
Old Nov 29, 2007 | 05:23 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
THIS IS WHY THIS FORUM IS GOOD!
Thanks for the post! I am cured of this one too, I am just going to do my own....
Old Nov 29, 2007 | 08:04 AM
76 sting's Avatar
76 sting
r
I have one of the 383 from the builder that does them for Year One. I have been to the manufacture and seen them put it on the dyno and even meet the owner, tour of the shop etc. They are roughly 2 hrs north of me in OK.
The best deal on the planet 3K for roughly 400+ hp and 400+ tq.
Old Nov 29, 2007 | 06:50 PM
Tankers's Avatar
Tankers
I also toured the shop and watched my engine get dynoed, very professional and a great engine. Here is the address http://www.dpmpower.us/home.htm
DO NOT buy from the all chevy shop (Lackey Performance Engines) on ebay, a total scam artist.
To complete motor off ebay
