1981 Frame
Old Nov 27, 2007 | 09:24 PM
Tony24's Avatar
Tony24
Default 1981 Frame
Have a 69, 76, 78 and 81. Are the frames the same on all four? If they are, does anyone have a frame diagram with measurements they could post. I really need one for the 81. I bought it wrecked (not bad), it ran up under something. My problem is the power steering pully is touching the front cross member. I do not know if the frame is bent a little or if the motor moved a bit.
Would appreciate any advice.
Thanks,
Tony in Houston, TX
Old Nov 27, 2007 | 10:41 PM
joehalford01's Avatar
joehalford01
the later frames are different but only by a little i believe. The biggest difference is going to be the tranny crossmember. The later years only have one indent for the single exhaust, earlier years had two holes for dual exhaust to pass through.
Old Nov 27, 2007 | 10:42 PM
72LS1Vette's Avatar
72LS1Vette
Thanks,
Tony in Houston, TX
76 and 78 should be the same. 69 has a different rear section and different body mount height. I think the 81 has the aluminum rear differential section and may have frame differences to accomodate that. Check BarryK's website. He used to have frame diagrams posted there. The good thing is higher production numbers for later year Vettes means more reasonably priced frames are available.
Rick B.
Old Nov 27, 2007 | 10:55 PM
SIXFOOTER's Avatar
SIXFOOTER
81 frame dimensions;
Frame Checking Proceedure
Old Nov 27, 2007 | 11:09 PM
71rdster's Avatar
71rdster
These guys are in Houston and may be able to help with a replacement frame, or in getting your frame straightened if it is salvageable.
http://www.gulfcoastcorvette.com/arm.htm
Uptmors Corvette Parts in the Waco area (an Ebay store) sells frames for reasonable prices, and are close to minimize freight cost.
Old Nov 28, 2007 | 12:28 AM
Aggitated Monkey's Avatar
Aggitated Monkey
I bought it wrecked (not bad), it ran up under something. My problem is the power steering pully is touching the front cross member. I do not know if the frame is bent a little or if the motor moved a bit. :
Was the engine hit from the top maybe pushing it down. If so you may have bent an engine mount horn. Take a look at the frame dimention post and you will see the mount horn I'm speaking of.
Old Nov 28, 2007 | 08:55 PM
Tony24's Avatar
Tony24
Default Thanks,
Thank's everyone, the information is very helpful. The rest is left up to me.
Thanks again,
Tony
Old Nov 28, 2007 | 08:59 PM
Artsvette73's Avatar
Artsvette73
Here is more information
http://www.71corvette.com/frames.html
To 1981 Frame
