vacumn pressure
Old Nov 28, 2007 | 03:34 PM
rthawk1's Avatar
rthawk1
Default vacumn pressure
I had trouble recently getting my right headlight to pop up. Left went up right away, but the right was very slow. No lift on the wiper cover.
I also had trouble getting the wiper door cover to lift...could pull it up with my fingers, but not with vacumn pressure on its own.
I replaced all the hoses with a new kit hoses...they had to still be originals.
After replacement I still have the same problem...great left (improvement)on the left light, but absolutely no lift on the right and none on the wiper cover.
Obviously I have a vacumn pressure problem, yet no leaks apprear around the intake manifold. Is their a way to check the pressure at each hose fitting? can I use the pressure gauge into a section of a hose....what should it read? can I use the same guage as would fit into a spark plug hole to obtain a pressure reading?
'72...350SB..K engine..auto..
thanks for all your assistance.....rt
Old Nov 28, 2007 | 03:47 PM
Gordonm's Avatar
Gordonm
Just a observation. Vaccum is not pressure it is vacuum. A pressure gauge will not work. You need a vacuum gauge instaed. Vacuum is just the oppisite of pressure. Your motor should produce anywhere from 12 to 18 inches of vacuum. I run at 9 inches and it is enough to operate my headlights and wiper door.
Your vacuum tank may have some small pinholes in it and is not holding vacuum. Check the vacuum at the port on your intake first and start working from there.
Old Nov 28, 2007 | 04:17 PM
...Roger...'s Avatar
...Roger...
Take a pair of pliers and pinch off the yellow striped hose going to the wiper side and see if the headlight goes up.
Old Nov 29, 2007 | 07:58 AM
bashcraft's Avatar
bashcraft
Vacuum is pressure. A negative pressure. My guage reads both negative and positive pressure.
Old Nov 29, 2007 | 08:04 AM
pws69's Avatar
pws69
Vacuum and pressure are mutually exclusive terms.
Your gauge reads pressure OR vacuum.
Old Nov 29, 2007 | 08:28 AM
bashcraft's Avatar
bashcraft
My guage reads positive pressure (boost) AND negative pressure (vacuum). The positive side (needle turning clockwise) is graduated in psi while the negative side (needle turning counter clockwise) is graduated in inches of vacuum.
Old Nov 29, 2007 | 09:07 AM
pws69's Avatar
pws69
Right......
Old Nov 29, 2007 | 10:53 AM
Gordonm's Avatar
Gordonm
Then you are all set. Pressure is usually measured in psi, vacuum is usually measured in inches of mercury. My gauge also goes both ways.
Old Nov 29, 2007 | 04:38 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Right......
??? There are a lot of boost gauges made that way.
To vacumn pressure
