Fuel Pressure
Old Nov 28, 2007 | 05:15 PM
wgbsigns's Avatar
wgbsigns
Default Fuel Pressure
i have a big block with barry grant six shooter, elderbrock victor fuel pump (mech) and a regulator. set float levels to center of sight holes with engine running. but when i shut off the motor the float level of the center carb always goes up to the top. start it back up and it will run till the float goes back down to the set level. then it is fine till i shut it off again. back up it goes. my drag racing friend says dont worry about it if it is not flooding down in the motor. but it doesnt seem right to me anyway. also why just the center carb. they are connected with a fuel log, and they all should have the same pressure. do i need a return line or less pump or dont worry about it? thanks, greg
Old Nov 28, 2007 | 05:56 PM
lars's Avatar
lars
You have a leaky needle/seat if the fuel level is rising after shutdown. I've also seen BG castings with porosity that will cause the same problem. The fuel level should not rise after shutdown if nothing is leaking.
