Accel HEI Distributor
Old Nov 28, 2007 | 09:24 PM
kansas123's Avatar
kansas123
Default Accel HEI Distributor
This has a mechanical tach drive but I believe that the crossgear needs replaced. What I need to know please is if the distributor needs to be pulled in order to do this and if I should buy a 'kit', not just the gear. It's on my '72 and was put in place of the stock unit. Thanks. I guess I could look at the stock unit but since they are not the same......I don't know the number of the HEI.
Old Nov 28, 2007 | 09:35 PM
Roughrider's Avatar
Roughrider
Why not simply contact Accel and ask them?
Old Nov 29, 2007 | 01:03 AM
LB66383's Avatar
LB66383
Usually, if the crossgear is chewed up, the drive gear on the distributor mainshaft is chewed up too. I'd want to pull the distributor and take a real good look. Putting a new crossgear on a bad mainshaft gear will just chew up your new gear.
To Accel HEI Distributor
