Oil valve assembly
Old Dec 1, 2007 | 01:37 AM
myc3's Avatar
myc3
Default Oil filter assembly
Is there a gasket or sealer required when a new oil valve assembly is installed? This is the threaded pipe and base that you screw the oil filter onto. Is the oil filter gasket the only thing that prevents leaks.
Old Dec 1, 2007 | 09:12 AM
myc3's Avatar
myc3
bump
Old Dec 1, 2007 | 09:35 AM
Artsvette73's Avatar
Artsvette73
I am guessing you are talking about the filter by pass valve that is bolted to the block. No sealer is used
Old Dec 1, 2007 | 11:09 AM
myc3's Avatar
myc3
Yes that is the part. I was not sure what the proper name was. I bought the part to install on my new 400 block but could find no instructions in any of my manuals. Thanks for the reply.
To Oil valve assembly
