Rear end gear
Old Dec 1, 2007 | 07:05 AM
gbags's Avatar
gbags
Default Rear end gear
78 stock L-48 WHAT REAR END GEAR?
Old Dec 1, 2007 | 08:40 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Standard transmission 3.36.1 or 3.70.1
Auto transmission 3.08.1 or 3.55.1
depends on options the car came with new.
Old Dec 1, 2007 | 10:11 AM
sly vette's Avatar
sly vette
If it's like most I have seen it will be a 3.08
Check it by marking the rear tire and the driveshaft and count the revolutions each one makes!
Old Dec 1, 2007 | 11:57 AM
dmayhew's Avatar
dmayhew
Default only 1 way to know for sure
Since the ratio could have been changed then the only way to know for sure is to check it out at the rear end.
Too much trouble to remove cover and count teeth unless you want to service the fluid whlie at it.
You could jack up the car and have a buddyturn the rear wheel 1 full turn. You will be under car and mark a spot on drive shaft and count the turns it will be close enought to tell if it turns are...
just over 3 times 3:o8, or 3.5 times 3:55 or 3.75 times 3:70
If speedo and tach are working the use that.
3:55 on P225/70 tires will give ~2650 rpm
David
To Rear end gear
