What Is This Switch??
Old Dec 1, 2007 | 02:53 AM
colin75's Avatar
colin75
Default What Is This Switch??
What Is The Black Thing With Wires Plugged Into It Under The Windshield Res Bottle On A 75? I Touched It And It Turned Into Mulch. After Adding It To My Flowerbed I Thought I Might Need A New One. What Is It And What Does It Do
Old Dec 1, 2007 | 10:01 AM
Durango_Boy's Avatar
Durango_Boy
Don't know, but here's a bump.
Old Dec 1, 2007 | 10:09 AM
...Roger...'s Avatar
...Roger...
What color are the wires?Where do they lead?
Old Dec 1, 2007 | 10:59 AM
Lee H's Avatar
Lee H
Just check my 75 and the only switch near the the wiper reservoir is a switch in the A/C line but it's along side not under. Mine does not have a switch or wires under.
Old Dec 1, 2007 | 11:33 AM
colin75's Avatar
colin75
it mounts to the bracket right next to the alarm switch. the wires are yellow and black.
the black is where the switch was sitting? the plug just pushes right on to top of the switch
Old Dec 1, 2007 | 01:06 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That's probably the alarm anti-tamper switch. Sets off the alarm if someone jacks around with the key cylinder.
Old Dec 1, 2007 | 03:05 PM
colin75's Avatar
colin75
found the switch and it looks right thanks. is this necessary to have or can it wait?
Old Dec 2, 2007 | 02:16 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I doubt the alarm would work right without it, but if you're not playing with that noisy, ineffectual alarm it's utterly unnecessary.
Old Dec 2, 2007 | 09:28 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If he tamper switch is removed, the alarm horn will blow all the time. Similar to if you opened the door or the hood and tried to set the alarm!
This switch is the same switch as the headlamp open switch found in each of the headlamp buckets.
Is this the switch you are looking at?
http://willcoxcorvette.com/product_i...ducts_id=24163
To What Is This Switch??
