Timing Revisited Again
My timing came out this
18 degrees at idle with the vac disconnected
36 degrees by 3000 again with the vac disconnected
38 degress at idle with the vac connected.
Does this sound right.
Yes i have read the sticky and every paper written about timing and tuning. Just wanting to run these numbers by you all.
Any input is appriciated.
Now for the carb i hooked the vacuum gauge up to see where it is and im at 12hg. The Car is running rich at idle. I have the idle mixture screws turned 1 turn out. The choke is open. The carb is a Holley 4160 Dual Feed Vacuum Secondary 750. Does it sound like i need a power valve? if so what one? from what i understand it would need a 5.5 pv. Thanks in advance.
from your numbers anyway it looks like it's supplying 20º advance at idle but at what vacuum level does it start and be all in at?
you want to make sure that the vacuum can supplies the vacuum advance all in at least 2"hg BELOW the vacuum level that your motor is producing at idle so for example if your motor is producing 20"hg at idle as you state than you want the can to have the advance in by 17"hg or 18"hg.
Also, make sure the total timing WITH the can connected does not exceed 52º.
i'd also reconnect the vacuum gauge to your carb and make sure your idle mixture is correct, not just connect it to read the vacuum level. With the vacuum gauge connect to a full manifold vacuum source adjust your idle mixture screw(s) to achieve the highest steady vacuum reading. You may need to readjust the idle speed during this process to keep it at the correct level. Once you have the idle mixture set than reread what the motor vacuum is at idle and compare that to the specs on the can to make sure that the vacuum can you bought is bringing in all the advance at least 2"hg below the motor vacuum level
