exhaust
Old Dec 5, 2007 | 11:27 PM
RobT's Avatar
RobT
Default exhaust
tonight while my project was running I noticed one sidepipe had alot
of exhaust coming out and the other side had little or none coming out,
one side has a baffle and the other doesnt.
but still you would think we would get something coming out.
you think we got something pluggin it up?
Old Dec 6, 2007 | 02:29 AM
vho69's Avatar
vho69
the one side must be leaking some where
Old Dec 6, 2007 | 02:38 PM
longbros's Avatar
longbros
If you have a heat riser valve in one side, the passenger side, then very little will come out until the valve warms up and opens.
Old Dec 6, 2007 | 06:51 PM
LB66383's Avatar
LB66383
Unless it's rusted shut, like they all do eventually.
Old Dec 6, 2007 | 06:53 PM
Speed Hound's Avatar
0Speed Hound
Former Vendor
check that valve see if it's your problem
Old Dec 7, 2007 | 12:01 AM
CCrane65's Avatar
CCrane65
Just replace the valve with an adapter for $20. Those stupid valves always rattle and sound like crap anyways. I wired mine open until I can get to the muffler shop to get the adapter put in. Sounds tons better already.
cc
Old Dec 7, 2007 | 01:23 AM
RobT's Avatar
RobT
Default valve
I have headers and sidepipes on this 76
would it have a valve?
if so where would I find it?
Old Dec 7, 2007 | 03:20 PM
LB66383's Avatar
LB66383
The heat riser valve is part of the factory exhaust manifold. If you have headers, you removed the valve when you took off the exhaust manifolds.
To exhaust
