oil pressure
Old Dec 6, 2007 | 08:13 PM
tonyro's Avatar
tonyro
Default oil pressure
what is a normal reading for oil pressure at idle?
Old Dec 6, 2007 | 08:15 PM
nastee383's Avatar
nastee383
Depends on your oil pump, etc. But 15 on the low end to 40 on the high end.
Old Dec 7, 2007 | 03:25 PM
C3 4ME's Avatar
C3 4ME
As a general rule of thumb, about 10 psi for every 1000 rpm.
Old Dec 7, 2007 | 03:56 PM
birdsmith's Avatar
birdsmith
Under normal conditions with 30 wt. oil and mild temperatures you should see 30-40 psi at idle when cold, and this will drop to 15-25 psi when hot assuming you're using a stock oil pump.
Old Dec 7, 2007 | 06:25 PM
7T1vette's Avatar
7T1vette
Many stock Chevy V8 engines/oil pumps will only generate about 10 psi at warm idle. It's not a big deal with a stock engine. If you have high-lift cam with solid lifters, you need higher idle pump pressure.
Old Dec 9, 2007 | 05:39 PM
jerrylee's Avatar
jerrylee
Mine startsout @60 staying there for a while before dropping to 40...............
Old Dec 9, 2007 | 07:05 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I've got the old Z28 oil pump in mine and its stays at about 55 at 800 rpm.
Old Dec 10, 2007 | 02:56 PM
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
My indicated oil pressure stays at 40 p.s.i.
Old Dec 11, 2007 | 06:08 PM
StickShiftCorvette's Avatar
StickShiftCorvette
If you want to confirm that 10 psi is OK, you will find that information in an '69 owner's manual.
To oil pressure
