poly mount bushings install c3
Old Dec 7, 2007 | 03:23 PM
car71's Avatar
car71
Default poly mount bushings install c3
hi does any body know which order the poly bushings go on i was told the thicker one goes between body and the frame ? thanks ps. did not come instructions.
Old Dec 7, 2007 | 04:00 PM
SIXFOOTER's Avatar
SIXFOOTER
Mine had two pieces that were shapped differently. The piece that is flat on both dides goes on the frame and the one with the rounded top goes on top
Old Dec 7, 2007 | 04:45 PM
car71's Avatar
car71
thank for the help
Old Dec 7, 2007 | 11:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Of course, the #4s are different (at least on the cars I've seen) - the cone-shaped piece goes in between the frame and body if the mount plate is in good shape. If it's marginal (like mine), use the hockey-puck shaped piece on top of the plate and very large washers to shim the gap.
Old Aug 9, 2009 | 05:34 PM
Grumpy 427's Avatar
Grumpy 427
I need help with this as well, why the heck cant they send instructions with this crap? I need pictures, i have a hell of a hard time comprehending this?
To poly mount bushings install c3
