Choke Pipe Function On Q-Jet ?
Old Aug 8, 2009 | 09:13 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Default Choke Pipe Function On Q-Jet ?
Does the choke pipe and choke hose enable the choke to operate properly ? Starting the car is becoming an adventure lately. If it doesn't start on the 1st try I'll have to floor it to start it and then feather the pedal for a bit...Once it's warmed up, it will run as advertised. I'm going to get the carb rebuilt over the winter , but I think I may just have a choke problem....I found the choke hose to have a slit in it the long way so it is apparently compromised.I'll fix that tomorrow , but any info would be appreciated.....
Old Aug 9, 2009 | 01:28 AM
CCrane65's Avatar
CCrane65
The choke pipe and hose was for the old thermalquad carburetors. You should not have one on your C3.
Yours should have a choke coil mounted on the intake manifold with a rod connecting it to a lever on the airhorn for the airflap (butterfly) and a choke pulloff vacuum pot.
At least that's the way early C3's are.
cc
Old Aug 9, 2009 | 02:41 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
cc
The choke hose connects to a vacuum port on the thermostatic coil assembly unit(lean/rich adjustment),then to the choke pipe , which snakes down into a vacuum port in the manifold....It's a '79 350 L-42 and it is there and very stock. In the '79 shop manual on page 6C-22, Fig. 6C-28 view shows it .That is my exact set up.
Old Aug 9, 2009 | 04:08 AM
Z-man's Avatar
Z-man
When the engine is cold, and you look at the carb with the air cleaner off, is the choke closed? That's the easiest way to tell. It should snap shut when you touch the throttle a bit.
It sounds like the deteriorated pipe has made your choke non-functional.
Old Aug 9, 2009 | 04:15 AM
jotto's Avatar
jotto
When the car is cold, the choke will initially be open if it is operating correctly as the last time you used the car, it should have opened fully.
When you go to start the cold car, you should pump the throttle to the floor once to release the choke so that it will snap closed. She should then start.
As mentioned above, remove the air cleaner and check when cold after car has fully cooled from a normal working temperature. If the choke is open, manually move the throttle linkage and you should hear and see it snap shut. If not there may well be a problem with the choke mechanism.
The split in the pipe would possibly only cause slow warm up problems if I am thinking correctly....lol
Old Aug 9, 2009 | 07:13 AM
Ganey's Avatar
Ganey
Originally Posted by jeff79'
... I'm going to get the carb rebuilt over the winter , but I think I may just have a choke problem....I found the choke hose to have a slit in it the long way so it is apparently compromised.I'll fix that tomorrow , but any info would be appreciated.....
Besides fixing the hose, you may need to adjust the choke richer.
Old Aug 9, 2009 | 07:28 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
1) 1st the choke hose will be replaced
2) The choke pipe is in perfect shape.No deterioration.
3) I will cold check the choke as recommended by Jotto
4) As Ganey recommends,a richer setting may be in order.It is leaned way out....almost to the max.( I wonder why ? )
Thank you guys for the lesson in choke operation and your recommendations..I'll let you know how it turns out. .
Old Aug 9, 2009 | 09:34 AM
7T1vette's Avatar
7T1vette
The Chevrolet Chassis Service Manual for your year will contain detailed procedures on setting up the choke system, as well as set-up for the carb adjustments.
Old Aug 9, 2009 | 09:48 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
I've got it and have been studying it.
The choke does close on a cold pedal pump, so that's cool.
NAPA opens at 10am so I have to wait to get vacuum hose.
I did adjust the lean/rich to 1 notch lean.It was almost pegged all the way lean, probably due to someone messing with it while it sat for 15 years w/o as much as a tune up.
Details to follow.
Old Aug 9, 2009 | 10:34 AM
ED79's Avatar
ED79
With air cleaner off notice that choke butterfly closes, when it starts, the butterfly should open about 1/4"(can use drill bit as a gauge) if is open more, then adjust the choke pulloff screw(I think turn it clockwise) until it reaches this measurement. It may take a couple of cool mornings to do it. Hope this works!!!!!!!!!ED
Old Aug 9, 2009 | 10:46 AM
falconview's Avatar
falconview
if you have or can borrow a vacume pump, you can apply vacume to the choke circuit and visualy see what the front flap is doing, it should also be riding on a fast idle cam that puts you in fast idle till the car warms, the line going into the manifold brings engine heat to the choke which causes the spring to expand and thus rotate the choke flap, if the line is clogged or sometime clogged at the intake manifold even a carb rebuild won't help you'll get the same problem...should check this first.
Old Aug 9, 2009 | 11:02 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
HOLY CRAP !!! What a difference ! Between riching the choke out to 1 mark lean and sealing both ends of the choke pipe with new vacuum hose, the thing starts up perfectly after 1 foot mash and then just turning the key.The fast idle is working fine and once the oil pressure is up, I get instant response from the pedal......I will however take ED79's advice and be sure the choke opens to 1/4 in....Too late now though, it's gotta cool down......When I turn the key when it's hot, it starts immediately, like 1/2 a crank....
THANK YOU GENTLEMEN !!!
Old Aug 9, 2009 | 02:46 PM
7T1vette's Avatar
7T1vette
You are welcome. But, you really need to thank the [original] GM engineers who designed the system. When you set it up as the Service Manual specifies, it works like "new".
Old Aug 9, 2009 | 03:20 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
If I see them I will.........This is just another step in getting a car back into perfect running condition starting with a battery,calipers & brakes, water pump , thermostat, harmonic balancer, etc. One thing follows another and I'm almost there.It rained after the initial test , but the sun is out now, so I haven't been able to take it out for a sufficient test beat yet.
I can't wait until next summer when the suspension gets redone.Priorities...You know ?
Well....Time for the 1/4 " drill bit test!
Old Aug 9, 2009 | 06:02 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
Man ...What a difference!...I'm loving it !...1 pedal mash on a cold start and Vrooom!....No pedal on a hot start and Vrooom!....Instant pedal response is back when it's all warmed up too....The choke opens a ch over 1/4" when cold started and she idles @ 6 hundo steady, cold or hot.BACK TO NORMAL !....Hmmm, I may not even need a carb rebuild....Thanks again boys !..
Old Aug 9, 2009 | 06:10 PM
Ganey's Avatar
Ganey
HOLY CRAP !!! What a difference ! Between riching the choke out to 1 mark lean and sealing both ends of the choke pipe with new vacuum hose, the thing starts up perfectly after 1 foot mash and then just turning the key.The fast idle is working fine and once the oil pressure is up, I get instant response from the pedal ....
That's what some of us expect.
To Choke Pipe Function On Q-Jet ?
