Dirty ports
Old Dec 7, 2007 | 07:19 PM
Thinpockets's Avatar
Thinpockets
Default Dirty ports
I just changed from an Edelbrock single plane intake with a Holley carb to an Edelbrock Performer with a Quadrajet (SB 350). Much better low end and throttle response. Feels like a different car.
When I had the intake off I noticed that the intake ports in the heads were black. It surprised me because I would have thought they would be very clean. What would cause this? Should I be concerned?
Old Dec 7, 2007 | 11:23 PM
gingerbreadman1977's Avatar
gingerbreadman1977
i think your holley must have been running rich. and no i think as long as it wasnt caked up junk it will be fine.
Old Dec 7, 2007 | 11:26 PM
BB72's Avatar
BB72
It might be something coming through you PCV valve on you valve covers. Extra blow by on you bottom end would cause excess oil coming through the PVC.
Old Dec 8, 2007 | 06:47 PM
Thinpockets
Thanks - I hope it's the running rich one.
Old Dec 8, 2007 | 07:10 PM
Dantana's Avatar
Dantana
Were you dumping fuel in there with a 750 or larger double pumper and a single plane intake? I was doing that for awhile on a previous car w/ a 750 and a Weiand Xcellerator and noticed the same condition on the intake ports.
Old Dec 8, 2007 | 07:37 PM
Thinpockets
When I bought the car 2 years ago it had a Holley 750 DP on it but it had a bad power valve. It oozed gas even when idling. I put a more reasonable sized Holley SA 570 but in spit of the fact that it was a pretty stingy sized carb it always had an unburned fuel smell to it. I hope this Q-jet is the answer. I'd sure hate to think that it may be a ring problem.
Old Dec 8, 2007 | 07:49 PM
...Roger...'s Avatar
...Roger...
Would a cam with a lot of overlap cause this?
Old Dec 8, 2007 | 09:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Big cam with lots of overlap causes reversion and will blacken the intake ports
Old Dec 9, 2007 | 01:21 AM
Thinpockets
I'm pretty sure it's stock. Has a real smooth low speed idle.
Old Dec 9, 2007 | 02:08 AM
bisrael's Avatar
bisrael
You may have considerable carbonization in your combustion chambers if it was running rich for long. You might want to pick up some "Sea Foam" from your local auto parts. Bring it in through the vacuum into the intake (follow instructions). It works very well. You may notice a difference in performance because carbon build up can really screw up the thermal dynamics of the motor.
Old Dec 9, 2007 | 06:13 AM
...Roger...
I wonder if a really rich idle will smooth out an otherwise lopey cam?
Old Dec 9, 2007 | 10:01 AM
Thinpockets
Makes me giddy just thinking that I may have a lopey cam . . . . but I don't think so.
I have run, with the SA570, the mixture so lean that I get real bad low speed surging and yet it would still idle well.
I just went out and looked inside the old manifold and it has a damp oily coating. The area under the carb is comparatively clean. The worst of it is at the bottom of the runners, including the tops (roofs) of those runners. I also swabbed the inside of the PCV vacuum line and found very little there. If this was coming from a rich carb wouldn't there be residue everywhere?
Is it possible this is a valve problem?
To Dirty ports
