odometer not working
Old Dec 7, 2007 | 10:08 PM
jagan's Avatar
jagan
Default odometer not working
Installed a new cable on my 68' and the speedometer is working but not the trip or miles odometer. Is the cable not engauging correctly or is my odometer shot? This is a project car so I don't know if it worked for the previous owner.
Old Dec 7, 2007 | 10:13 PM
RadicalPursuit's Avatar
RadicalPursuit
Default Odometer
You might try lubricating the gears inside the speedometer with graphite and lubricating the reset cable might help. I think resetting the trip odometer can cause the odometer to sometimes jam.
Old Dec 7, 2007 | 10:24 PM
jagan's Avatar
jagan
I was hoping that I would not have to take the speedometer back out of the car as it was a real PITA. Why did'nt GM make all the dash assembly a pigtail plug hook up?
Old Dec 8, 2007 | 12:22 AM
CCrane65's Avatar
CCrane65
Unfortunately, you will likely have to take the speedo back out to replace the worm gear in the odometer. They are made of nylon and regularly wear out.
Corvette Central sells a brass replacment gear that I would recommend.
cc
To odometer not working
