Front X-member under radiator...
Old Dec 8, 2007 | 11:31 AM
carriljc's Avatar
carriljc
Default Front X-member under radiator...
I bought a new front crossmember for my 68 (the one under the radiator) because mine had the bottom rusted out. This thing is built quite oddly; same as original, but it appears to be 2 pieces spot-welded together...that means that it is not exactly "sealed"....so water can get in it.....I suspect that how my old one rusted out. Anyway, I was thinking about drilling a couple of drain holes...that is after I coat the inside with paint; I took a flashlight and looked inside---it's bare metal.
Here's a picture:
Any ideas? Opinions?
Old Dec 8, 2007 | 11:36 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Good idea.........anything's better than nothing...............
Old Dec 8, 2007 | 12:03 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
can you finish wire welding the seams together to help with the seal? or get enough paint inside to rustproof it?
Old Dec 8, 2007 | 12:25 PM
carriljc's Avatar
carriljc
Default I thought about wire welding the 2 parts....
I'm not sure it's worth it....looking at my old rusty one, it doesn't seem to provide much structural support. That's why I thought drilling drain holes was a better idea. It's quite obvious that it's rusty inside...my old radiator leaked for years and I'm sure it got inside. Actually on the old one the rust appears to be causing the 2 spot welded parts to separate.
I can pour some primer and paint in through the tapped bracket holes....and then find the low point for a drain hole.
I guess I'll head that way (if I can quit being lazy and just go outside).
Old Dec 8, 2007 | 05:06 PM
Aggitated Monkey's Avatar
Aggitated Monkey
I would just pait it and install it and not wory about it for another 39 years.
Old Dec 8, 2007 | 06:59 PM
72LS1Vette's Avatar
72LS1Vette
I would spray something like chain saw oil or Eastwood's rust inhibitor inside rather than primer and paint. Drain holes are a good idea. The factory never intended these cars to last for 30 or 40 years when they were built so they didn't bother with rust preventative measures.
I remember (dimly) that new cars in the 50's and 60's would start having rust-throughs on body panels after only 2 or 3 years.
Rick B.
Old Dec 8, 2007 | 07:27 PM
carriljc's Avatar
carriljc
Default I was just going to install it...
...but I peeked inside and saw it was bare metal...it's just too easy to pour something in there; instead of knowing it's bare metal. And drilling the holes is easy too.
What's this rust inhibitor stuff?
I can't spray anything in there, I'm going to pour it in....that's why I was think primer and paint might be the easiest.
Old Dec 8, 2007 | 09:19 PM
66RAY's Avatar
66RAY
I am also doing my cross member and I scuffed it; used Eastwood Rust Inhibitor and painted it with Chassis Black. I figure I'll be long gone before it fails again. I just posted a question about my radiator surround. When I took off my cross member I saw rust on the surround and am going to replace it. Any problem with yours?
Old Dec 8, 2007 | 09:58 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
why not use some great stuff foam filler in it to seal it up? it would just expand inside of it and come out the holes and then you can cut off the stuff that comes out when it dries. this stuff expands like crazy and im sure it would keep water out.
http://greatstuff.dow.com/
Old Dec 8, 2007 | 10:05 PM
ZD75blue's Avatar
ZD75blue
Great stuff is bad stuff for cars. When it shrinks and goes chalky it absorbs water. Stay away!
Old Dec 8, 2007 | 10:42 PM
carriljc's Avatar
carriljc
Default I pulled my radiator surround a couple of years ago...
..and it's in quite good shape. I cleaned it up and painted it. So that's all good.
So, now it's just a decision on what the heck to pour inside. They make that eastwood inhibitor in a brush-paintable/"pourable" liquid?
Old Dec 9, 2007 | 02:01 AM
jyounane's Avatar
jyounane
Default Old fashioned way...
I use fish oil in an aerosol can and spray it in. Try to tilt the cross-member around so that the fish oil runs into the seams.
This stuff is excellent...smells for a while but the odor goes away and it does work!!!!
Joe
Old Dec 9, 2007 | 10:12 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
I agree, I did the same thing on some trucks years ago and a few years later they were acting like a sponge!
Old Dec 9, 2007 | 12:24 PM
72LS1Vette's Avatar
72LS1Vette
You can find info on the Eastwood rust inhibitor on their website. It's made for inside areas that won't be painted. Supposed to adhere well to metal and remain flexible. Chain saw bar oil is very sticky because it has paraffin in it and can be bought cheaply at any home center or place that sells saws.
Rick B.
Old Dec 9, 2007 | 10:36 PM
66RAY's Avatar
66RAY
Eastwood's rust inhibtor comes in liquid form (I got pints in red because it was on sale. Sticks like glue.)
To Front X-member under radiator...
