Rally Wheel Painting
Old Dec 8, 2007 | 07:32 PM
Kim72's Avatar
Kim72
Default Rally Wheel Painting
I'm trying to repaint my wheels. After sanding them and cleaning them with silicone remover I still am getting fish eyes. Looks like sh_t!! Using VHT paint I've used before with good results. Not sure how to fix this. Any experience with this??
Old Dec 8, 2007 | 08:59 PM
wnmech's Avatar
wnmech
I like wiping my surfaces with lacquer thinner. Did you prime the wheel before you shot the final coat? I have seen the fish eye occur when you just shoot some paints directly on to the surface thats why i like to primer first.
Old Dec 9, 2007 | 03:02 AM
7T1vette's Avatar
7T1vette
You may have put too heavy a coat down. If the Argent Silver paint "pool", you can get that problem. Multiple light coats give better results than one heavy coat.
Old Dec 9, 2007 | 08:14 AM
timgman's Avatar
timgman
Most likely oil on there.. armor all or tire shine...
clean of with paint thinner and you'll rock.
Old Dec 9, 2007 | 12:38 PM
Kim72's Avatar
Kim72
Paint thinner!! I never thought about that. I assumed I would need silicone remover to clean them first. Can I now do the thinner over the fresh paint I've laid down and then just re-spray them?? Thanks for this info. I was thinking I would have to bead blast them.
Old Dec 9, 2007 | 02:56 PM
CCrane65's Avatar
CCrane65
It's best to start over and use the paint thinner to prepare the surface prior to applying any paint.
cc
Old Dec 9, 2007 | 03:04 PM
corbyscott's Avatar
corbyscott
I just painted mine last monday. I sand blasted them, wiped them down with laquer thinner, then used krylon primer, then sprayed them with the silver. No problems at all and they look a lot better.
Old Dec 9, 2007 | 03:07 PM
wallifishrmn's Avatar
wallifishrmn
I had the same problem although I sprayed the paint over a cleaned painted surface. Just wipe the fish eye area while still wet--it smears the paint but will get covered up with the next coat. I gave mine 4 coats and they look great.
Paul
Old Dec 11, 2007 | 09:26 PM
battjke's Avatar
battjke
Sand the fish eye area then wipe down with laquer thinner and respray several light coats
To Rally Wheel Painting
