Problem with HEI Coil
Old Dec 9, 2007 | 01:20 PM
papawana's Avatar
papawana
Default Problem with HEI Coil
I added an Accel Brutethunder coil to my stock hei coil (Lars rebuild and fine tune)...I put the distributor in with new Accel cap and rotor set, installed new spark plub wires...but did not put on the new coil cover just then as I did not have a black cover (got it today)...when I started up the car to time it (as per Lars instructions), I notice that there were mini sparks coming from the black ground wire feral attached to one of the 4 coil attaching screws...is this normal?
Old Dec 9, 2007 | 05:31 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I can't imagine anything in a car that generates sparks in an open environment would be normal. While I could be wrong, if I'm understanding what you are describing, I'd say it is a dangerous situation and that the car should not be driven until repaired. Perhaps you can contact Lars.
Old Dec 10, 2007 | 01:59 PM
papawana's Avatar
papawana
emailed Lars...no answer yet...anyone else?
Old Dec 10, 2007 | 02:27 PM
Jud Chapin's Avatar
Jud Chapin
Keep us posted.
Old Dec 10, 2007 | 03:25 PM
hugie82's Avatar
hugie82
Did you use enough Dia. grease on the rubber insulator washer?
Old Dec 10, 2007 | 04:11 PM
ltlevil's Avatar
ltlevil
Hate to ask the obvious but is the connection clean and secured?
Old Dec 10, 2007 | 11:13 PM
papawana's Avatar
papawana
the connection was clean. and tight..all new parts...grease on both sides of the rubber insulator ring between the new coil and new cap...got a reply from Lars (great guy)...got feed up...so installed the 29 year old coil...no sparks...returning new hp coil tomorrow...end of story...thanks bunches
Old Dec 11, 2007 | 07:40 AM
Jud Chapin's Avatar
Jud Chapin
Good deal!
Old Dec 11, 2007 | 08:39 AM
strokervette's Avatar
strokervette
I had this problem too with all kinds of replacement parts to my HEI new cap, rotor, coil, wires and finally a new distributor. I was figuring on a miss so I got one of those clear caps that you can see the individual sparks inside and I was amazed at the inconsistancy. I went to a separate coil style MSD distributor and problem solved. Most will say the Hei is good enough but not for me after what I saw, even with EVERYTHING replaced. I have a more "racer" style setup and I'm not using any mech advance or vac advance, it's locked out at 36 with an MSD digital 7 box using the 20 deg. start retard feature with great results.
The main reason I went this route was because with the old setup I couldn't get a steady reading with the timing light no matter what I did.
To Problem with HEI Coil
