Removing fuel hoses from pump
Old Dec 10, 2007 | 12:37 PM
dgruenke's Avatar
dgruenke
Default Removing fuel hoses from pump
I am having a very difficult time removing the rubber hoses at the bottom of the fuel pump. I don't recall that they have ever been off of the pump. I even tried to use Vise-Grips to pull them off, but I don't want to damage the hoses.
Any tips on how to remove these?
Old Dec 10, 2007 | 12:45 PM
noonie's Avatar
noonie
Use vise grips or pliers to twist the hose first to break any bond, once they swivel, then you should be able to pull them off.
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
sharp blade, cut off hoses near metal ends, then cut along lenght of hose and peel off
Old Dec 10, 2007 | 12:51 PM
dgruenke's Avatar
dgruenke
I tried doing that, but there just isn't much room to rotate a set of vise grips. I will try that again, though.
Old Dec 10, 2007 | 12:52 PM
dgruenke's Avatar
dgruenke
I really don't want to cut them because the hose is nearly a custom fit and I don't want to not have enough hose to reconnect it.
Old Dec 10, 2007 | 01:03 PM
...Roger...'s Avatar
...Roger...
If you know what a cotter pin puller looks like they make one for removing hoses.
Old Dec 10, 2007 | 01:28 PM
sweethence's Avatar
sweethence
if they are that old you need to replace em anyway, while they do make "molded" hose i hear, any standard fuel hose will work. the trick is to put the fuel pump end on, and twist/ turn the hose till it lines up with the tank line without kinking, pice of cake
cheers
tim
Old Dec 10, 2007 | 02:32 PM
Willis76's Avatar
Willis76
Just be careful and play it safe - those lines could be full of gas. Protect your eyes and clamp those hoses shut before you pull the lines from the pump.
Old Dec 10, 2007 | 02:53 PM
GlockGuy's Avatar
GlockGuy
cheers
tim
^Good point. They tend to get hard and brittle. Easy to replace with new hose and hose clamps.
Old Dec 10, 2007 | 04:22 PM
Patrick73's Avatar
Patrick73
Slit the 2 hoses where they attach to the fuel pump, remove and then put on 2 NEW hoses. Now is the time to do it while you are replacing the fuel pump. They need replacing if they are the original ones. I recently did this job.
Old Dec 10, 2007 | 04:29 PM
GlockGuy's Avatar
GlockGuy
My car is also a 76. If I remember correctly, I had to use a tubing cutter to cut some of the steel line that ran up to the pump. This gave enough room to install a short piece of rubber fuel line.
Old Dec 10, 2007 | 05:08 PM
7T1vette's Avatar
7T1vette
Yes. Cut the hoses off and replace them with GM direct replacement fuel line. No one in their right mind re-uses 35 year old fuel line (unless they are totally "****" about the 'original' thing or they work for the local fire department).
Old Dec 10, 2007 | 08:10 PM
gkull's Avatar
gkull
Before you pull the hoses have the gas tank empty or the front end jacked up 12+ inches
The pump has direct feed because it is lower than the tank. You pop the hose off be ready for gas flowing.
With the clamp off you can get a pry bar behind the rubber and wedge it off. It is a PITA!
Old Dec 11, 2007 | 07:15 AM
RunningMan373's Avatar
RunningMan373
I changed mine w/o that knowledge, and the gas will just keep -Pouring - out of the now open fitting, lost about a cup of gas. I just cut a slit down the old hose witha sharp sheet rock knife after i remove the clamp and pry it in half with a flat blade screw driver. Works every time. Direct fits are good, but you can use a stock hose if you rotate it so it is not kinked, works fine.
Old Dec 11, 2007 | 09:21 AM
a kungfu mastah's Avatar
a kungfu mastah
and replace the hose while your at it. i would personally use a scalpel to slit it, but it seems most people dont have access to one =\ theyre also great for splinters too.
Old Dec 11, 2007 | 08:33 PM
dgruenke's Avatar
dgruenke
I wasn't planning on replacing the pump. It looks like Corvette Central has the "S" hose for about $12 and the straight one for about $8. Looks like I will just cut and replace.
To Removing fuel hoses from pump
