guy's, decided to build my L48 instead of buying a crate, got edlebrock 60909 heads, 3701 intake, cause my '79 has to pass Ca smog. I am keeping the quadrajet, it has the heat tube for the choke, fits right on the intake but not in the hole for the heads heat crossover, first thought was to switch to electric, I called Edlebrock being unhappy with their head design, talked to a guy named Ron, told me to just cut the heat tube under the intake, hook up the choke as stock. OK, so seems to me you'd be pushing exhaust straight into to carb, what would you guys do?
Don't know if you're joking or not but this is not a good idea.
BigBlockk
Later.....
I guess I did forget the sarcastic smiley. I was not 100% there last night, I forgot to add that whoever he went to was a little off on their suggestions.
