U-Joint install Question
Old Dec 13, 2007 | 06:26 AM
RunningMan373's Avatar
RunningMan373
Default U-Joint install Question
I got a new set of Spicer U-joints, they came with these little black plastic caps that hold the cups onto the body of the joint. When i go to install these, do I remove these little covers, or install with them? I can see the tripple seal in the U-joint cup itself, pressed in with a little copper holding. So, Do i need these, or should I remove them? they are very fragile, two have cracked allready
Old Dec 13, 2007 | 07:16 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think you need those. The Neapco Brute Force joints have similar seals, but red instead of black. I didn't break any of the Brute Force seals, even when I screwed up installing one joint and shattered the cap while trying to get it back out.
Old Dec 13, 2007 | 07:28 AM
RunningMan373
Were yours plastic or metal, 'cause these are plastic and very fragile, the seals are still in the joint. I am just having a hard time imagining them useing this cheaap plastic garbage on a $25 U-joint. ??? wtf. ug.
Old Dec 13, 2007 | 07:46 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I don't like the idea of the seals being cracked. Here's a Spicer web site where you can contact them to get some answers. I couldn't find a phone #.
http://www.spicerparts.com/default.asp
Old Dec 13, 2007 | 09:16 AM
Jud Chapin's Avatar
Jud Chapin
You're welcome!
Old Dec 13, 2007 | 09:26 AM
RunningMan373
thanks,
Talked to Spicer tech support, what they said was that the cap is intended to be installed, it was a known problem all ready addressed, and but that when the joints were tested in mud, water -ect that the caps were not even on to U-joints, and spicers are suppose to be pretty good. So seeing that only 2 are cracked, i'll think i'll use them. thanks for the help,, Chris.
Old Dec 13, 2007 | 09:28 AM
Jud Chapin's Avatar
Jud Chapin
Good deal! Thanks for the info.
Old Dec 13, 2007 | 10:32 AM
rponfick's Avatar
rponfick
Why not ask Spicer for some replacement caps for the ones you broke? I would suspect they would want to keep you happy.
Ralph.
Old Dec 13, 2007 | 11:02 AM
RunningMan373
Ralph.
parts go in today. thanks.
Old Dec 13, 2007 | 04:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Red plastic. Hard stuff, and well-bonded to the metal cap.
To U-Joint install Question
