whats the winter project?
Old Dec 13, 2007 | 08:10 AM
sonnystingray's Avatar
sonnystingray
Default whats the winter project?
For those of us in the North East , its time to put the cars on the shelf for the winter.( it sucks, but what can you do?)
On the positive side, it gives me ample time to do the minor things that I have put off during driving season.
I buying a 4 post lift for the garage next week( Greg Smith Equipment out of delaware) Hopefully this will make a few of the projects easier.
I plan on replacing the rear transmission seal.Investigate my oil pressure unit.
trouble shooting the headlight vacum system.
What projects are planned for your car?
Old Dec 13, 2007 | 08:21 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I'm sure you'll enjoy the lift. Wish I had one. As a side issue, you could always move to Florida.
Old Dec 13, 2007 | 09:58 AM
Durango_Boy's Avatar
Durango_Boy
I'm gonna finish up my grills, re-do some wiring with custom harnesses, clean everything up with paint and looms, finish my fuel door project, and MAYBE install my TH200R4.
Old Dec 13, 2007 | 11:15 AM
sly vette's Avatar
sly vette
I got my car at Vettes By Design as we speak for the final phase.....PAINT!!!!
Old Dec 13, 2007 | 11:26 AM
Sully1882's Avatar
Sully1882
my 72 coupe will be getting the old black paint stripped and then the prep work will begin to get it ready for the new steel cities grey paint job... oh and install of the new dewitts radiator.... should be fun and keep me busy all winter long.
Sully
Old Dec 13, 2007 | 12:17 PM
MixxMaster's Avatar
MixxMaster
Bare minimum: Re-install gas tank, Fiberglass in front and rear bumper panels, replace body mounts, fiberglass in new hood scoop, final body prep for paint.
If time/money permits: Remove engine/prep engine bay for paint.
Remove wiring harnesses. Sand/Paint Engine, Frame. Install new fuel/brake lines.
I still have hope to have her in paint once spring starts.
Old Dec 13, 2007 | 12:50 PM
LOTSARED's Avatar
LOTSARED
Default Engine rebuild !
1968 Roadster, in upper Midwest--
I seldom work on the car over winter, but this winter is different!
As we speak the 427 is out and in the hands of a close friend / mechanic. It's the original engine and we rebuilt it 21 yrs ago. It had started smoking and getting weak, so decided to "freshen" it up.
Well that freshening has evolved into a complete rebuild with mild mods. Since this car has been very stock/original all it's life, I'm looking fwd to the gentle mod. Will retain as nearly 100% stock appearance as possible (I like that look anyway). But the engine is getting a new set of Edelbrock aluminum heads, a slightly more agressive cam, and 454 crank. Keeping stock intake an exhuast manifolds, but with 2-1/2" exhaust & Flowmaster mufflers. Not looking to build insane power, but it will certainly pull a bit harder than ever before.
Will install before Spring. Also hoping to attack vacuum system issues (headlights & wiper door), interior light switches, and a cpl other small items before Spring "rollout". April will be fun!
Old Dec 13, 2007 | 12:53 PM
PatsLs1vette's Avatar
PatsLs1vette
Bodys coming off,completely doing frame over again in silver pearl.Replacing anything thats bad in front suspension.Ls1 is coming apart ,cam swap,porting the heads.Stripping body back down ,repainting it and adding motion paint scheme in the silver pearl stripes.All in the same time of adding an addition to the house 16x28 and either moving my garage/shed14x28 to back of yard or building new 24x24 garage instead and getting rid of what i have.I got alot to do,that doesnt include all the other cars i work on too.
Old Dec 13, 2007 | 01:12 PM
CJ 77's Avatar
CJ 77
It gets inspected in January so it wont be lifted until after inspection. I'd like to pull the old A/C and convert it to latest. I think its R34? Change the trans filter & gasket. Fix my warped hood ( Im working on that now). Maybe just clean up the engine compartment.
Old Dec 13, 2007 | 01:21 PM
blunblk68's Avatar
blunblk68
lets see
1.new outer door handles,mirrors,and rear bumpers
2.new speedo cable
3.all new autometer gauges in white face including speedo,tach,fuel,etc..
4.new taylor wires (blue),and new black hei cap to get rid of the red one to stay with the blunblk theme.
Old Dec 13, 2007 | 01:28 PM
BKbroiler's Avatar
BKbroiler
I plan on installing a Hurst line lock and Dragvette halfshaft safety loops. I'm also going to change trans fluid and filter and change my coolant, including draining the block since I will be under there so much anyway.
Old Dec 13, 2007 | 01:51 PM
another-user's Avatar
another-user
ive got a list about a mile and a half long.
at the very least, i want to get my back up lights working, new exhaust installed, and rebuild my convertible top.
Old Dec 13, 2007 | 04:06 PM
76 VETTE's Avatar
76 VETTE
I want to take tail shaft off 350 tranny and change speedo drive gear.Went from 3:08 to 3:55 gears. Has anyone changed theres for this gear ratio.What drive & driven gears did you use?Its a 76.Thanx
Old Dec 13, 2007 | 04:59 PM
Silver73SB's Avatar
Silver73SB
Just ordered a 420 lb spring from VBP to replace my 330 and the ac system after that.
Old Dec 13, 2007 | 05:08 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Wow!!! Impressive list Pat. Are you going to be able to get it all done this winter? I just hope my winter is not as long as yours.
I hope to get my LS1 motor in mine. I already have installed the new cam. I have my 243 heads out there ready to go. I just need new springs and pushrods to finish the motor assembly. The next project would be fuel system. I have yet to buy a piece of it.
Old Dec 13, 2007 | 05:18 PM
tyancey00's Avatar
tyancey00
My winter has already started. A bunch of guys came over and took out tne motor and trans. I have no Idea how to put it back together so I guess I might as well rebuild it. Heads, pistons, cam, manifold... I want 350 hp!! New A/C unit, old one shot craps. Fix steering... then buy beer and have those guys come back and put it back together. I hope they make it through the winter..... I will need them in the spring.
Old Dec 13, 2007 | 05:33 PM
Durango_Boy
Dude that's easy. You doing the work in that hangar? I wanna help too.
To whats the winter project?
Old Dec 13, 2007 | 05:35 PM
BKbroiler's Avatar
BKbroiler
No need to take the tail shaft off. You only need to change the driven gear which comes out by removing one bolt, after you unscrew the cable. I went from 3.08 to 3.73 and you need to do a little arithmetic to change the number of teeth on the driven gear by the same percentage as 3.08 compared to 3.55. You need to increase the tooth count so you can slow down the speedometer. Zip Products sells the driven gears.
Old Dec 13, 2007 | 06:49 PM
gmans71's Avatar
gmans71
my winter project is to repaint a friends 72.. look for pics of the progress being made..also installing a furnace in the garage..
Old Dec 13, 2007 | 06:59 PM
MakoShark72's Avatar
MakoShark72
ZZ4
2004R
Vintage Air
Paint in the spring
Interior
