transmission linkage leak
Old Dec 14, 2007 | 05:28 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
Default transmission linkage leak
well i took the transmission out of the car in April and steam cleaned the outside and put a new pan gasket on which got rid of the leaking on the passanger side but it is now leaking from where the shifter linkage hooks up on the tranny. is that hard to fix? im not planning on fixing it till after i move to the new house and i just want to know what i can expect before thinking about even doing this.
Old Dec 14, 2007 | 05:32 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
what kind of tranny? TH350?
Old Dec 14, 2007 | 05:35 PM
LIQUIDDRAGON
oops. i forgot to mention that it is a TH350. thanks
Old Dec 14, 2007 | 05:45 PM
Scott Marzahl's Avatar
Scott Marzahl
That linkage seal is pretty easy to change. Remove the shifter linkage from the shaft that goes into the trans case, and with a small pick or screwdriver you should be able to remove that seal. If it doesn't come out easily that way, then you may need to drop the pan, disconnect the shaft on the inside, slide it out and then remove the seal so you don't scratch up the shaft or damage the case. It is a lip seal, lubricate the shaft and new seal and be careful when installing the new one not to damage the lip. Once you get it located and started, you can use an appropriate size socket to tap it into place. Good luck.
Old Dec 14, 2007 | 06:21 PM
LIQUIDDRAGON
Originally Posted by Scott Marzahl
That linkage seal is pretty easy to change. Remove the shifter linkage from the shaft that goes into the trans case, and with a small pick or screwdriver you should be able to remove that seal. If it doesn't come out easily that way, then you may need to drop the pan, disonnect the shaft on the inside, slide it out and then remove the seal so you don't scratch up the shaft or damage the case. It is a lip seal, lubricate the shaft and new seal and be careful when installing the new one not to damage the lip. Once you get it located and started, you can use an appropriate size socket to tap it into place. Good luck.
thanks for the quick reply
Old Dec 14, 2007 | 08:54 PM
SIXFOOTER's Avatar
SIXFOOTER
Your going to have to drop the pan and remove the nut and arm from the shaft on the inside and then remove the linkage. Then the seal will come out, its a metal framed seal, pop it out with a screwdriver from the outside. Tap the new one in with a block of wood and a hammer.
Old Dec 14, 2007 | 11:00 PM
Vette Gator's Avatar
Vette Gator
I bought the tool that allows this seal to be removed without dropping the pan. Worked like a charm.
http://www.toolsource.com/shift-leve...r-p-72369.html
Old Dec 14, 2007 | 11:26 PM
LIQUIDDRAGON
thanks for the link i'll order one in a week or so after i get situated in my new place. thanks again.
Old Dec 16, 2007 | 10:17 AM
squirrelguy's Avatar
squirrelguy
Ditto on the "thanks for the link". I have a turbo 400 with the exact same leak, and had heard about this labor saving tool, but had no Idea where to find one. Thanks again.
Old Dec 16, 2007 | 10:58 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Is the transmission still out? If so, the tool will work great. If you've put it back in then the tool seems to be hit and miss because of the variable clearance in the tunnel. If you can't get the tool in place, just drop the pan and remove the shaft as mentioned above. Not hard, just much more time consuming.
Old Dec 16, 2007 | 11:19 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Another good tip is that you can usually tap two seals in there..one on top of the other. Works well when the shaft is starting to get a little wear.
JIM
Old Dec 23, 2007 | 09:11 AM
squirrelguy
I have a 1970 with a turbo 400. Can I assume that this proceedure is the same?
Old Dec 23, 2007 | 09:54 AM
Scott Marzahl
Same seal.
Old Dec 23, 2007 | 12:31 PM
7T1vette's Avatar
7T1vette
You should be able to "pop" the seal out pretty easily. Just get a small (3" or shorter) screwdriver or an icepick. Push the tip of the tool into the inner rubber area of the seal so that it goes through it and under the casing of the seal (just needs to be under the edge of the metal). Lay the shank of the tool down across the other side of the seal/pilot boss on the housing and use the heel of your hand to hit the handle on the tool. It will pop one side of the seal out of the bore and you can remove it. Just be sure that you don't do any damage to the OD of the shift selector shaft or the seal bore on the housing. Also, when you press the seal back in, make sure the housing bore is clean and dry [as you can make it] and press/tap it into place with the back side of a socket of approximately the same size as the seal. Push/pound it in straight down to flush with the housing. DO NOT **** THE SEAL AS YOU INSERT IT. Some folks put some Loctite sealer on the OD of the seal. If the casing on the seal appears to be painted, don't put sealer on it. That "paint" is the sealer.
Old Dec 23, 2007 | 01:15 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I have the same issue.. Maybe a few pics to help some of us out would be great....
Thanks for the help
Old Mar 17, 2008 | 05:34 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I remembered reading this back in December, I went out and since my car was on jackstands, checked it, it was fine. Yesterday I am out there tighting up the header collectors and I get in the face by a drop of tranny fluid. Now its leaking, car hasnt moved.
Anyway, the link to the tool isnt finding the tool. Anyone know where I can buy this seal remover?
To transmission linkage leak
