How much time to change Differential?
Old 12-14-2007, 09:59 PM
Derby98
Derby98's Avatar
St. Jude Donor '09
Default How much time to change Differential?
Anyone done a R&R on a rear differential?
How long should it take a "qualified" mechanic?
thanks
Old 12-14-2007, 10:07 PM
wombvette
wombvette's Avatar
You mean drop the complete assembly out and put another in? 3 Hrs.
Old 12-14-2007, 10:15 PM
Derby98
Derby98's Avatar
St. Jude Donor '09
Yes, remove old unit & install new.
3 hours does not seem to be too bad.
Thank You.
Old 12-14-2007, 10:17 PM
wombvette
wombvette's Avatar
Thank You.
Naturally that depends on what you run into, rust, bubbas, etc.
Old 12-14-2007, 10:53 PM
Solid LT1
Solid LT1's Avatar
Car may have to be re-aligned after installation. Take that into account when pricing job. I do this stuff myself, not too difficult to do with a set of jackstands and floor jack. With the money you save you can buy yourself a aircompressor and impact gun at Sears!
Old 12-14-2007, 11:07 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
In three hours I might have everything organized and ready to start a re and re of the diff, c'mon be realistic, sure I could remove my motor in 3 hrs too but it usually takes me all day to do things correctly and still have both fenders left on the car
Old 12-14-2007, 11:21 PM
Derby98
Derby98's Avatar
St. Jude Donor '09
The reason I asked is that a local shop quoted me 5 hours labor to swap diffs.
I have all the air tools etc.....I might just try doing it myself.
Old 12-14-2007, 11:35 PM
woodlandcorvette
woodlandcorvette's Avatar
Yes 3 hrs sound about right it took me less then a hour but I already had the trailing arms off and the half shafts removed and I have little to no rust. It took about 3 hours to remove trailing arms assemblies and half shafts when I did those. The rear was quick after that I needed to change the yokes and clutch pack while Im in there.
Do it yourself and save the money it was a fun job in a good way and they wont paint and clean it up like you will. Looks so much better after por-15 and paint but adds to you rebuild time. But I have all winter anyway so times not a issue.
Good Luck
Old 12-15-2007, 02:49 AM
77TSi-meez
77TSi-meez's Avatar
spraying the rust alone will take all day/maybe longer to allow
for easier removal.
Old 12-15-2007, 06:10 AM
mrvette
mrvette's Avatar
The largest time wasting issue will be the removal of the cross member, is it's stuck in place as most are....first time, it took me an extra 2 hours to get that damn thing off the frame....once THAT finally gave all the rest was easy....
first time through it, count on an all day job....
Old 12-15-2007, 08:14 AM
dmaaero
dmaaero's Avatar
Be very careful with the air tools, if you over tighten the center leaf spring bolts they can crack the housing also the leaf spring end bolts are fine thread. fine thread and air tools dont get along to well
Old 12-15-2007, 08:21 AM
Chuck-75
Chuck-75's Avatar
Old 12-15-2007, 10:15 AM
Glass Act
Glass Act's Avatar
Location: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Changed our 79 four times, took me almost 7 hours each time and I have a hoist, so I wasn't working on my back with jack stands. I could freely stand while un-hooking / removing everything. Plus everything (trailing arms, half shafts etc) were less than a year old, so not rust, dirt or stuck parts to deal with.
Before someone ask why 4 times, removed the 3.55's installed 4.56's ran those for a bit, loved the take off, hated the fuel mileage. Re-installed the 3.55's, missed the take off, went back to the 4.56's and they will stay in.
And let's not forget the beer and pee breaks.
Old 12-15-2007, 10:24 AM
63mako
63mako's Avatar
St. Jude Donor '08-'09
Yep, sounds like everybody is right. 2 hours to gather tools and spray everything down with PB Blaster then put everything back when done. 3 Hrs to R&R and 2 hours for beer and pee breaks. looks like a 7 hr job to me.
Old 12-15-2007, 10:33 AM
wombvette
wombvette's Avatar
He did say experienced mechanic. I would bet the flat rate time is no more than that. But, I have done these for 35 years. I know what to remove and how to do it. I also take the unit down as an assembly with the spring, cross member etc. attached. A quick change and back up. Naturally I am assuming that the mechanic has a lift. I dont blame the guy for quoting 5 hrs. though, you never know what you will run in to.
Old 12-15-2007, 10:38 AM
wombvette
wombvette's Avatar
Hey, mr , You just didnt have a big enough crow bar.
Old 12-15-2007, 10:59 AM
Derby98
Derby98's Avatar
St. Jude Donor '09
Thanks Lads.
I too have hoist & I am not pressed for time so I think I will try it me self especially because I like to clean & paint as you reinstall & as you guys say a shop mechanic is not going to that much detail.
PS: Air tolls for removal etc... I always tighten by hand & use a torque wrench where appropriate.
To How much time to change Differential?
Old 12-15-2007, 11:09 AM
7T1vette
7T1vette's Avatar
Received 2,715 Likes on 2,273 Posts
The time to change out a diffy is dependent on many factors.... How rusty and locked up the bolts are; how big and burly you are; how cold it is in the garage....and the most important factor....how many beers you have available! [The more beer you have, the more time it will take.]
Old 12-15-2007, 11:26 AM
battjke
battjke's Avatar
It really isn't too hard....do it yourself, you will learn a lot and have peace of mind that it is done right.
Old 12-15-2007, 11:27 AM
Derby98
Derby98's Avatar
St. Jude Donor '09
There's NEVER a shortage of Beer!!!
Quick Reply: How much time to change Differential?
