383 Crate Specs
Old Dec 16, 2007 | 12:30 PM
pj_corvette's Avatar
pj_corvette
Default 383 Crate Specs
Hi all
I came across this engine they are selling here in town.
Just thought I would post the specs, to see what you think, especially with respect to the cam.
Thanks...
New GM 4 bolt main roller block,
line honed,
ARP main studs,
3.75” Scat Cast Iron Crankshaft,
5.7” Scat Rods,
AFR Aluminum Cylinder Heads 195cc Intake, 68cc Combustion Chambers, 2.0 intake, 1.60 exhaust valves, 7/16 rocker studs - These cost me $1490.
Comp Cams XR270 hydraulic roller cam,
forged pistons, 10.0:1 compression
Melling hi-volume oil pump,
brass freeze plugs,
harmonic balancer and flexplate,
oil pan,
timing cover,
all ARP fasteners and Fel-Pro gaskets,
balanced by Basko Engine Service in Gilbert.
Also included:
Power+Plus CrossWind polished intake manifold #52025 similar to airgap(new in box still)it is #8 on this link - http://www.partshp.com/Manifolds.htm
Here are the cam specs:
Comp Cams
Camshaft Part # 08-422-8
Designation XR270HR-10
ADV DUR 270 / 276
Duration @ 0.050" 218 / 224
Max Lift w/ 1.5RR .495 / .502
Lobe Separation 110
Valve Lift: .495 .502
Old Dec 16, 2007 | 02:26 PM
1972warship's Avatar
1972warship
Originally Posted by pj_corvette
Hi all
Thanks...
line honed,
ARP main studs,
5.7” Scat Rods,
brass freeze plugs,
oil pan,
timing cover,
Also included:
Comp Cams
ADV DUR 270 / 276
Lobe Separation 110
I have that cam(with 1.6 rockers) in a 383 with 180cc heads and it is mild. About 16.5 inches of vacuum at 800rpm
Old Dec 16, 2007 | 04:09 PM
pj_corvette
That's what I was thinking, that it may be too mild.
But then I could replace it with the XR276HR, or the XR282HR. Just don't know if the last one would be overkill.
I'm open to comments/suggestions for other cams too, and about the rest of the parts.
Just figured I could reuse the other Comp-Cam roller hardware he has there already if I use one of the cams I mentioned.
Old Dec 16, 2007 | 05:36 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
The 282 would not be overkill.
Old Dec 16, 2007 | 06:21 PM
billla's Avatar
billla
St. Jude Donor '14
Not enough cam for the AFRs as noted - but otherwise that's a VERY nice combo!
Old Dec 16, 2007 | 09:28 PM
VettePower's Avatar
VettePower
What is their asking price?? Seems like a good combination to me.
Old Dec 17, 2007 | 01:40 AM
jackson's Avatar
jackson
I doubt if block is NEW ... clues are line hone & 383" w/ 3.75" stroke ... probably a LATE oe roller block. Seller does not id piston mfg p/n.
Old Dec 17, 2007 | 02:22 AM
pj_corvette
Price is $2800
what is line honing?
Old Dec 17, 2007 | 07:33 AM
billla's Avatar
billla
St. Jude Donor '14
Not sure why this would be a clue; if they're using a new GM block and changing from bolts to studs AND putting in a new crank I'd align hone it too. Many crate engines start with the new GMPP blocks...as do I for ground-up builds.
Good catch regarding pistons; brand and P/N would be good
Old Dec 17, 2007 | 02:40 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
ON a stroker the cam will not be as rough as on a std. bore 350. You can also shop by LSA and if you investigate/shop/add that to the list/ you will have lots of options.
Old Dec 17, 2007 | 02:56 PM
billla's Avatar
billla
St. Jude Donor '14
Main align honing it to ensure the crankshaft bearing bore is concentric across all of the bearing saddles and to ensure correct bearing crush for each cap. Basically, it makes sure the crank bearing bore is the round, the right size and in-line. If things are way out of whack - or the engine's spun a main bearing - an align bore is sometimes required.
An align hone is required if the type of main cap fastner is changed (bolts to studs) and is generally recommended if you're spinning the engine regularly past 5500 RPM. There's a lot of debate on this - Vizard has a tendency to recommend doing a mock-up and if the crank spins freely leave it, but Yunick's take was "don't even check it - just align hone it". I generally align hone the block for a new crank, but that's just my experience.
To 383 Crate Specs
