What Size Torq Thrust and Tires
Old Dec 19, 2007 | 02:18 PM
Roeich's Avatar
Roeich
Default What Size Torq Thrust and Tires
Going to put Torq Thrust on my 69. I'm thinking 17" wheel, 255/45 ZR17.Any thoughts? What are you using on yours? Don't want any rubbing issues. Stock ones off, new bolt right on. Nothing else to do or be concerned about. Thanks
Old Dec 19, 2007 | 02:56 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
I am sure someone will chime in, I have been thinking aobut this one too. I THINK most are running 255/50/17 on the 17 x 8 TT with a 4" backspace
Old Dec 19, 2007 | 03:39 PM
Gordonm's Avatar
Gordonm
I have run a 17X8 with a 4 inch backsapce with no problems. Ihad 255 45 17s all around and none of the m rubbed. I tried 255 50 17s and the yrubbed on the front. I know run a 18X10 with a 5.5 backspace on the rear with 275 40 18s and the 255 45 17s on the front.
Old Dec 19, 2007 | 06:52 PM
Vetdremz's Avatar
Vetdremz
Rich,
Sent you a pm.
STEVE
Old Dec 19, 2007 | 11:08 PM
martinsw's Avatar
martinsw
Do you have offset trailing arms to get the 18 rears to work?
Old Dec 19, 2007 | 11:22 PM
sperkins's Avatar
sperkins
17's with 245/45/17. No problems.
Old Dec 20, 2007 | 04:54 AM
bisrael's Avatar
bisrael
I'm running 17" TT IIs with Nitto NT450s (255/50) all around. They are a great upgrade in handling compared to my stock 255/60x15 Goodyears. I don't have pictures, but here's a video of some track runs where you can get an idea of how they sit on the Vette.
Old Dec 20, 2007 | 07:28 AM
Gordonm's Avatar
Gordonm
No the stock arms will work fine. I just had to relocate the Ebrake cable.
Old Dec 21, 2007 | 05:53 AM
rsmith31's Avatar
rsmith31
Cruising
255 45 17 - perfect
Old Dec 21, 2007 | 05:57 AM
bisrael's Avatar
bisrael
Originally Posted by rsmith31
255 45 17 - perfect
If lowered a little bit, otherwise, your reveal might be a little large. Kind of a matter of taste though.
Old Dec 21, 2007 | 06:03 AM
rsmith31's Avatar
rsmith31
Cruising
Actually the car has been lowered about 2 inches since the photo was taken & looks 100% better.
Old Dec 21, 2007 | 06:32 AM
Fonz69's Avatar
Fonz69
Check out Tomzwheels
I just got my TT2's from him and they look great
255/50r17 with 4" backspace
great customer service, I will go back to him the next time I need wheels for sure
Old Dec 21, 2007 | 08:26 AM
Roeich's Avatar
Roeich
Thanks. Tomzwheels seems like the place to go.
Old Dec 21, 2007 | 08:47 AM
11Jake's Avatar
11Jake
I also just received my TT2's from Tomzwheels. Perfect transaction and a great price. Pete is the man you want to talk to at Tomzwheels!
Old Dec 21, 2007 | 08:51 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Go with the Nitto 275/50 17 in the rear. It gives the car a better stance.
[IMG][/IMG]
Old Dec 21, 2007 | 06:13 PM
1972warship's Avatar
1972warship
Just a question for you guys with the aftermarket wheels.
How did you have them balanced....
The hub centric way(ie just mount the wheel through the center hole when balancing) or the lug centric way(mount the wheel with an adapter with lugs).
I just ask this b/c I have had problems with aftermarket wheels that did not fit the hub of the car perfectly like the oem's. They would never balance just right.. ie shake around 57 mph
Old Dec 21, 2007 | 09:53 PM
bisrael's Avatar
bisrael
Mmm, at least with my correctly sized (offset, backspacing) TTIIs, I've had no such problems, at least up to about 130
To What Size Torq Thrust and Tires
