ps pump differences
Old Dec 19, 2007 | 08:44 PM
jnb5101's Avatar
jnb5101
Default ps pump differences
does anyone know what the differences are between the ps pump on a 72 vs 75? gm has different part numbers.
thanks,jeff
Old Dec 19, 2007 | 08:58 PM
Ironcross's Avatar
Ironcross
It could possibly be the hose connections. Early style pumps used flare fittings and hoses. Later model use "O" ring fittings and hoses. There are adaptors but not widely sold. The steering gears are similar in connections. One has to match the other........
Old Dec 19, 2007 | 09:45 PM
SteveG75's Avatar
SteveG75
Difference is that a '72 has a bolted on pulley with a keyway. '75 has a pressed on pulley.
As for the line fittings, '75 has flare fittings just like '72.
Old Dec 19, 2007 | 09:54 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
SteveG75 is correct about the pulley shaft difference.
The hose was the same from 1963-1979. In 1980 GM went to a different pressure hose with a different flared end. This remained the same from 1980-1982.
Willcox Inc.
Old Dec 19, 2007 | 10:26 PM
jnb5101's Avatar
jnb5101
thanks for the quick reply
jeff
Old Dec 20, 2007 | 01:31 AM
cduemig's Avatar
cduemig
I just put my ps pump back in and was going to replace it. I saw all the options and wondered the same thing since there are different numbers for the years, but they looked the same to me. I just decided to strip and paint mine
To ps pump differences
