Detent cable not returning to idle position
The detent cable doesn't seem to return to it's idle position, the carb just slides back through the detent cable's long slotted hole.
I assume there is a spring or something under the pan...anyone know if it's an easy fix?
TIA
A couple things I have seen to cause your symptoms are:
1. Broken cable
2. Broken detent rod in transmission.
3. Melted cable from touching headers.
4. Detent cable not installed correctly on detent rod.
Good luck and let us know what you fnd.
