O2 location
Old Dec 20, 2007 | 07:23 AM
77 vette's Avatar
77 vette
Default O2 location
Anyone know the correct clocking for a 4 wire heated O2 sensor? I'm installing the bumg in the reducer aft of the header collector. Should I install it straight up or on the side level with the pipes? Thanks
Old Dec 20, 2007 | 07:26 AM
Gordonm's Avatar
Gordonm
Install it at the 3 or 9 0'clock position. You do not want it at the 6 o'clock position due to moisture settling in the pipes. Mine is at the 3 o'clock position as are most factory O2 sensors.
SIXFOOTER's Avatar
SIXFOOTER
to the inside or outside, up would either hit the floor pan or really be a PITA to get to, down wouldn't clear the ground
To O2 location
