how hard will this be to fix???
Old Dec 21, 2007 | 11:44 AM
jcswm's Avatar
jcswm
Default how hard will this be to fix???
I was cruising around 90 and POP I'm sideways on I-275n in rush hour traffic ....my right rear tire ATE part of my fender
do they make patch panels or am I better off replacing the fender???
Old Dec 21, 2007 | 12:03 PM
Durango_Boy's Avatar
Durango_Boy
You can most likely patch that yourself. A good shop will have no problems patching that up. Matching the paint will be interesting though.
Just so you know, always check what speeds your tires are rated to drive at. Some are not rated for 90 especially when they are older tires.
Old Dec 21, 2007 | 12:08 PM
TopGunn's Avatar
TopGunn
Originally Posted by jcswm;1563265522
I was cruising [B
around 90[B] and POP I'm sideways on I-275n [B]in rush hour traffic[B]
Old Dec 21, 2007 | 12:39 PM
BHRIG's Avatar
BHRIG
Default Hard to Fix
YO FIX;
You should not be taking chances with speed with all that rust.
You might have been very lucky that all you did was the panel damage.
Check your whole car for rust before attempting high speed travel.
If something else let loose it could be much more costly.
Old Dec 21, 2007 | 12:55 PM
jcswm's Avatar
jcswm
Originally Posted by BHRIG
YO FIX;
????? my car is solid as a rock with some light surface rust on a daily driven car where are you seeing all this rust?????
Old Dec 21, 2007 | 01:44 PM
SIXFOOTER's Avatar
SIXFOOTER
I think he is looking at your frame in there. If its just surface rust its not a problem. Fiberglass work isn't that hard. Couple choices: Either replace the quarter panel or patch it. You might find that replacing the panel is the fastest and easiest way to go, as oposed to cutting, glassing, filling and smoothing the 2 or 3 areas that are affected there.
Eklers sells a video that covers that exact repair if your interested in doing it yourself. Paint is a whole nuther matter, matching can be tough on an old paint job
Old Dec 21, 2007 | 02:22 PM
jcswm's Avatar
jcswm
I'll look into that video
The 2K primer yellow will be easy to match!!! RED paint goes back on in febuary
Old Dec 21, 2007 | 03:12 PM
7T1vette's Avatar
7T1vette
Yep. Just by the right repair materials and "patch" away. Cleaning the area properly before patching is important (but a PITA). Ask around for the best "finishing" tools to use.
Old Dec 21, 2007 | 03:56 PM
Belgian1979vette's Avatar
Belgian1979vette
I think it will be easier and a better job to replace the intire panel. Painting will be the most expensive on this job.
Old Dec 21, 2007 | 04:35 PM
rcread's Avatar
rcread
Must be nice to live in a place where you can drive 90 mph during rush hour. In Seattle, you are lucky to top 15 mph. Was the wheel damaged?
Old Dec 21, 2007 | 04:52 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
Replace the panel
Old Dec 21, 2007 | 05:01 PM
wgbsigns's Avatar
wgbsigns
sorry but theres just no hope for the tire.
Old Dec 21, 2007 | 06:06 PM
stingraymaniac's Avatar
stingraymaniac
great time to get some flares!
Old Dec 21, 2007 | 08:17 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
looks like you can tackle that if you are inclined to. fiber glass is pretty easy to work with .....that rim needs to be checked for trueness before you mount a tire on it though
Old Dec 21, 2007 | 08:23 PM
mdbelanger's Avatar
mdbelanger
If ya think them rust holes are small wait till you look on the other side.
Body damage is minor, best to do first is see how bad that frame rot is before ya cruise at 90 any more.
Old Dec 21, 2007 | 08:39 PM
VettePower's Avatar
VettePower
Is this clown serious??? All I see is some very light surface rustish color!!!
Old Dec 21, 2007 | 08:45 PM
mdbelanger's Avatar
mdbelanger
Is this rust holes or rubber??????
To how hard will this be to fix???
Old Dec 21, 2007 | 08:51 PM
VettePower's Avatar
VettePower
Sorry! I don't have a magnifying glass with me.....
Old Dec 21, 2007 | 09:52 PM
jcswm's Avatar
jcswm
no rust holes..... just surface rust on a daily driver and busted fiberglass!!!
Old Dec 21, 2007 | 09:59 PM
bwellisley's Avatar
bwellisley
all the yrs livin in the metro area...never been above 60 in rush hour.....were you on the shoulder?! Maybe that's why the tire blew!
