Rear wiring harness??
Old Dec 22, 2007 | 10:59 PM
Merlinhaggard's Avatar
Merlinhaggard
Default Rear wiring harness??
I need a rear tail light wiring harness. Does anyone know where It plugs in (under dash) and where to run it?. I couldnt fing it in my AIM or chiltons..
Old Dec 22, 2007 | 11:05 PM
SIXFOOTER's Avatar
SIXFOOTER
Its a Long harness, feeds along the drivers side, up thru the door pillar and plugs into the harness behind the speedo
Old Dec 23, 2007 | 10:18 AM
Sully1882's Avatar
Sully1882
Default sixfooter is right
In my 72 and in my AIM the rear wire harness plugs into the underdash harness close to the fuse block next to the speedometer. It then runs under the kick panel and the carpet and door to the rear of the car. If you look in your AIM, year specific, even though 68-72 are very similar, and when you get to the section about the seats and before the rear compartment stuff... sorry I don't have mine with me so I don't know the page.... you can see where they plug into each other. Go directly to the maker of the wire harness like lectric limited instead of eckler's or midamerica. Good luck...
Sully
Old Dec 23, 2007 | 12:20 PM
Merlinhaggard
Sully
Cool I will look there. Thanks..
To Rear wiring harness??
