Trickflow Top end kit for L48
Old Dec 23, 2007 | 05:06 PM
mikep3's Avatar
mikep3
Default Trickflow Top end kit for L48
Has anyone used this top end kit on stock L48?
http://www.trickflow.com/largeimage....S-K314-350-400
Need to do a valve job and replace cam, timing chain/gears. So why not aluminum heads and slight CR increase with 64 heads.
78 silver anivr. L48 4spd, 3.36 rear true dual exhuast.
Old Dec 23, 2007 | 05:49 PM
Stroker-427's Avatar
Stroker-427
Good heads, but without a matched cam and intake you are wasting money!
The stock L48 camshaft have very low duration and lift, making it suitable for low RPM application with small intake ports..... the TFS heads have very good flow numbers (for the port size) but need at least some 230° @ 0.050" cam in order to give it's best...... may matched with the very good Edelbrock Performer RPM Air Gap intake!
My opinion is with this configuration you can have over 400 Hp with a good exhaust !!!!!
.....but the next weak part will be the bottom end..... at least, because the L48 have two Bolt Main Caps, you have to use ARP studs.
If you intend to change only heads, may you need some smaller port combo, like Edelbrock Performer or Performer RPM (basically the same heads (apart for the cross hexaust hole).
...just my two cents...
Old Dec 23, 2007 | 06:20 PM
Bud2's Avatar
Bud2
Bud2
Default Agree, but-
This kit also includes the cam. Do you mean that the included cam is not a good match to the heads?
Bud.
Old Dec 23, 2007 | 06:33 PM
Attfay Elleybay's Avatar
Attfay Elleybay
I think he missed that it came with the cam. I've noticed it's easier to miss things when reading from a screen.
Old Dec 23, 2007 | 06:36 PM
Stroker-427
OOps........ sorry!
...now in Italy is half pass midnight...... may I have to go to the bed!
Old Dec 23, 2007 | 06:40 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Cam looks pretty wimpy to me.
Old Dec 23, 2007 | 06:46 PM
my mach 5's Avatar
my mach 5
Different kits have different cams (obviously) for higher HP. Depends on what kit you want:
Here's another with a bigger cam: http://www.trickflow.com/egnsearch.a...9&autoview=sku
Old Dec 23, 2007 | 08:16 PM
77 vette's Avatar
77 vette
I have this kit on my 383, the cam is weak and the valve springs can't handle much more lift, I think .480" max lift, it does have a strong bottom end but falls flat at 5000 RPM. I do like the 110 LSA, gives it a nice sound at idle even with the small duration and lift, If I did it again I would have steped it up one level. Pease
Old Dec 24, 2007 | 02:15 AM
FRSTR90's Avatar
FRSTR90
Go to Summit buy the Edelbrock Performer RPM Head Combo package that comes with heads cam and intake slap a 750CFM carb of your choice and you'll easily have 420HP and you'll be spending weekends roasting your tires!!
I believe the head combo kit cost about $1500 or so..
Old Dec 25, 2007 | 06:00 PM
Stroker-427
The Edelbrock Kit is a very good one....... but please, pay attention to you bottom-end before to rev it at 6500 RPM for long time!!!!!
As I sed, minimum, you have to replace stock bolts with ARP studs in you main caps of your L48 two bolts block!
Old Dec 26, 2007 | 03:17 PM
jackson's Avatar
jackson
Default no way 400hp or more
No way those kits'll push even 400 fwhp from an otherwise stock OE L48 ... OE L48 has OE dished pistons ... OE L48 might, just barely make 9:1 scr when mated to 64cc alum heads & typical gasket for alum head. Do your homework ... lotta those kits' install instructions tell you big hp claims based on flattops & zero deck ... OE L48 has neither. Also ... mate an rpm cam ( or similar profile) w/ 9:1 scr & you'll get a dog ... too much cam for lo comp.
For a STOCK L48, You might consider heads w/ smaller chambers (ie L98 aka ZZ4 heads w/ 58cc chambers). 58cc will push OE L48 to at least 9.6:1. Those heads, a medium cam & good exhaust'll work wonders on an otherwise stock L48.
here's a good scr calculator & you can search this forum to find whatever data you don't know that needs to be plugged in ... it's been done before.
http://www.21cgt.com/FMWebCatalog/frmConversion4.aspx
Old Dec 28, 2007 | 12:05 PM
75 Waz's Avatar
75 Waz
Navigator
I have a 75, L48 4spd, 3.36, just like Mikep3's I was thinking of going with the Edelbrock Performer RPM kit. Do you guys really think it is going to be a dog on the bottom end. Maybe I need to go with the 2102 cam from Edlebrock. Sorry about the Hijack.
Old Dec 28, 2007 | 01:23 PM
jackson's Avatar
jackson
This been beat to death long ago many times ... maybe eb changed specs in that time ... I dunno I ain't gonna look it up again ... but it used to be fairly typical eb's plain performer cam was too small for most street folks ... while eb's RPM cam was too big for most street folks ... that eb didn't have a decent middle choice. Seems to me, most kits (regardless of brand) are a compromise for most folks ... if I'm building a motor & spending that kinda $ I want the parts that are optimally matched to what I have ... not necessarily the priciest nor the biggest ... but the best match.
used to be ... maybe same today:
  • performer cam was small aka "RV" cam ... responsive down low but soon runs outta breath. Great heavy/hauler truck cam ... hence RV.
  • RPM cam was too big for most street ... poor vacuum, poor response/dog down low.
Old Dec 28, 2007 | 06:31 PM
mikep3's Avatar
mikep3
75 Waz, I got mail from Jackson and Glensgauges about this subject.
If you stuck with the L48 bottom you need CR from new heads 64, 62 and 58 cc chambers on new heads will do some of that. Then you need a cam, wow these guys are hot on a big point too big is too big and too small is too small.
I think this is the best for me, http://www.sdparts.com/product/SD806...merIntake.aspx
with a cam like this http://www.sdparts.com/product/KITSD...5quotlift.aspx
On top of that, I have asked SDparts to see if I can get the head/intake combo with an Edelbrock performer airgap intake.
What do you think?
Old Dec 28, 2007 | 07:00 PM
my mach 5's Avatar
my mach 5
What do you think?
You can get this kit with the perfomer airgap intake: http://www.sdparts.com/product/SD806...formerRPM.aspx
Old Dec 28, 2007 | 07:03 PM
75 Waz's Avatar
75 Waz
Navigator
Mikep 3,
I didn't know that kit was out their. Looks good... Everyone keeps talking about this 270H cam. I guess that is why I am on this fourm, to get good information from guys that have been down this road before.
Thanks for all the help....
Old Dec 28, 2007 | 09:45 PM
FRSTR90's Avatar
FRSTR90
Sorry, I usually mention that. If you keep the RPM's to 5500 tops, it will be a great set up you wont be disappointed with!
To Trickflow Top end kit for L48
Old Dec 28, 2007 | 10:00 PM
Glensgages's Avatar
Glensgages
Originally Posted by jackson
..... I ain't gonna look it up again.....
I happen to have the '07 Edelbrock Catalog handy:
here is what is says for each, plus the 'Torker'-cam -
Performer - P/N 2102
Advertsied = 278* I / 288* E
@ .050" = 204* I / 214* E
Lift = .420" I / .442" E
LSA = 112*
Performer RPM - P/N 7102
Advertised = 308* I / 318* E
@ .050" = 234* I / 244* E
Lift = .488" I / .510" E
LSA = 112*
Torker-Plus - P/N 5002
Advertised = 292* I / 300* E
@ .050" = 232* I / 234* E
Lift = .488" I / .488" E
LSA = 108
I believe these are the only hydraulic/flat-tappet cams listed for SBC in this book:
once-again, Jackson is correct about not-much-choice.....
Old Dec 28, 2007 | 10:55 PM
Attfay Elleybay
Most of these kits list HP with 10:1 CR and open headers.
How much loss with 8.5:1 and semi-stock mufflers?
I have the L82 with headers and duel exhaust, and have been looking at these kits.
Old Dec 29, 2007 | 12:05 AM
bozzman3's Avatar
bozzman3
I went with the trick flow kit and it worked out great for my 1980 L82 My car put down 272 hp at the rear wheels.I used the 350 hp /400 ft lbs of torque kitSee my photos for the dyno sheet and time slips.Click on the pictures to enlarge
