Need advice on tire/wheel sizing
Old Dec 24, 2007 | 06:06 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Default Need advice on tire/wheel sizing
I have a flared (ZL-1's) '73, no parking brake, stock trailing arms...I would like to know what fits...I'm looking for the widest tire/wheel application in 17" or 18" and what offsets are required. I know a 315-35-17 on an 11" rim will work. Anyone else have suggestions? If an offset TA is required, I can make the change.
Old Jan 9, 2008 | 12:05 AM
wesleyshawn's Avatar
wesleyshawn
bump, I'm wondering the same thing.
Old Jan 9, 2008 | 09:18 PM
Jim_Harrison's Avatar
Jim_Harrison
Talk to John at Complete Custom Wheel, he will know.
Old Jan 9, 2008 | 11:40 PM
3JsVette's Avatar
3JsVette
Here's the info from Chris McDonald's web site on 18s http://mcspeed.homestead.com/Flare_Install.html
If you're going with 17s - the fronts would be 17x9.5 with 4.5 backspace with a 275/40 tire and the rear would be 17x11 with a 4.5 backspace and a 315/35 tire. You don't need offset rear arms with either of these combinations. Hope this helps.
Old Jan 10, 2008 | 12:03 AM
vettesbydesign's Avatar
vettesbydesign
How would you know all this,my friend????
Old Jan 10, 2008 | 01:00 AM
gkull's Avatar
gkull
I don't have offset trailing arms. I use 5 inch effective BS on the rear and 4 BS on the front 9.5 and 11 X 17
For driving on the street I use 315 rears. What suck about them is the 25.4 diameter. Smaller diameter = smaller contact patch. If you have traction problems with your previous race tires. You might consider 335/35/17 they are 26 inches in dia.
Speed Rating “W” = 168mph (270kph) 102W SL Treadwear: 30
Traction: C
Temperature: A30 C A
1874 lbs.
51 psi
4/32"
26 lbs. Rim 10.5-12.5"
12"
13"
NA
25.4"
821
335/35ZR17
Load Index 106 = 2094lbs (950kg) per tire
Speed Rating “W” = 168mph (270kph) 106W SL Treadwear: 30
Traction: C
2094 lbs.
51 psi
4/32"
29 lbs. Rim 11-13"
13"
13.9"
NA
26"
802
Old Jan 10, 2008 | 04:05 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Remember to inquire about backpad height for caliper clearance before committing your order, as this often varies among wheel lines that are even from the same manufacturer (such as with Compomotive).
FYI, my understanding is that a 5.5" BS is max with 17" rear wheels and offset TA's. At 11" width, that would yield a centered wheel backpad (good for the bearings) and would only require a minimally increased flare width.
Old Jan 10, 2008 | 07:35 AM
NMsharkracer
Thanks guy's...great information. Don't know how Chris McDonald can use a 4.5 BS on front. I test fit my Z06 wheels using spacers and the most I could get was 4.0 with the tire rubbing the frame at full lock.
Old Jan 10, 2008 | 08:37 AM
69autoXr's Avatar
69autoXr
Jack, if you really want to go wide...Danny Popp runs 315's and 335's on 11's and 12's front/rear on his flared C3. CCW should know the backspace on a similar setup, or contact Danny on the forum, his username is raftracer.
Old Jan 10, 2008 | 09:06 AM
wgbsigns's Avatar
wgbsigns
i have flared vette 73 stock arms 18x12w4.75"bs and 18x9.5w4"bs 335-30-18 & 275-35-18 fit perfect.
Old Jan 10, 2008 | 09:16 AM
NMsharkracer
[QUOTE=TheSkunkWorks;1563554521]Remember to inquire about backpad height for caliper clearance QUOTE]
Real good point. I was looking at getting 17" torque Thrust II's because I know my 15's clear the calipers...I'll have to check if 17's have the same height.
Thanks...
Old Jan 10, 2008 | 09:18 AM
NMsharkracer
Talked to Danny last week and got a whole lot of good advice on suspension setup...
Old Jan 10, 2008 | 09:19 AM
NMsharkracer
I'm going to use 17's but similar BS...thanks
Old Jan 10, 2008 | 09:52 AM
gkull's Avatar
gkull
Like i said before. I'm going to run 295/17 Kumho 710 fronts on 9.5X17 rims with 4 inch BS
Old Jan 10, 2008 | 04:39 PM
68/70Vette's Avatar
68/70Vette
When I had factory trailing arms, the largest 17 inch tire I could use was a 225/50 R17. Even at that the emergency brake bracket on the trailing arm looked a little too close to the sidewall (3/8"?). I thought about moving the bracket a little ( a welding job) but then thought - oh heck - just buy offset trailing arms which I did. With my offsets I think I move up to 255/50 R17's.
Old Jan 10, 2008 | 05:16 PM
NMsharkracer
Me too in front...
To Need advice on tire/wheel sizing
