Vacuum and Carb help needed... bad!
You need to figure out if it's vacuum related or an mechanical Issue.
Basically you have one feed vacuum line connected to the big cylinder looking thing behind the bumper area. From the feed tank it supplies vacuum to the individual light assemblies. There is also the control vacuum line that determines what position the main vacuum is feed. The control valves are located behind the head lights.
Check your vacuum lines. Sucking on the control line will move the valve from one position to the other and bring the lights up/down. Mech issues are a little harder. Reach in there and move the headlight manually and see if anything is binding. Watch the paint. I would bet it being the vacuum lines as the engine is also displaying leak symptoms.]
Good luck
Dave...
Good luck
Dave...
http://www.ecklers.com/product.asp?p...66&dept_id=224
BigBlockk
Later.....
Good Luck, Paul
I'm hoping this means the problem was a stuck needle. I've since tightened the adjusting nut to almost the lowest fuel level and cleaned up the mess I made. Once the fuel dries I'm gonna start her up, w/ the screw covering the eye hole off, and slowly raise the fuel level until it just begins to trickle out. The engine also sounded a hell of alot better, not to mention I wasn't creating a fuel air bomb out of the development w/ my exhaust! However, my headlights and wiper door still don't work. Which brings me to a question for you Vette heads out there!I'm gonna go through and systematically eliminate my potential vacuum leak. I want to start at the top and work my way down.... mainly to ensure the engine is tuned w/ the correct vacuum pressure..... that being said:
If I'm going to plug one of the vacuum lines to insure that the leak is no longer in the loop, what is the very 'first' line I should plug? Right after the carb? Tank? Perhaps something to plug while tuning the carbs float and idle mixture...., a way to ensure I have correct vacuum pressure for at least the time being. I figure if you can help me figure the first, most essential spot at which I can plug the system, I'll tune it there then go back after she is tuned and work my way down through the rest of the vacuum system, systematically unplugging and plugging various odds and ends til the leak is located. Thanks again for all the help guys!
