Bent Strut Rods
Old Dec 26, 2007 | 12:31 PM
CCrane65's Avatar
CCrane65
Default Bent Strut Rods
I just noticed that Bubba bent the strut rods on my vette. Can they be straightened?
cc
Old Dec 26, 2007 | 12:34 PM
Gordonm's Avatar
Gordonm
Yes they can. Most of them were bent because they could not get any more adjustment from the rods. Usually a sign of worn suspension components.
Old Dec 26, 2007 | 12:39 PM
Garys 68's Avatar
Garys 68
I'll bet that bending them strait will not allow for the proper camber adjustment in the rear.
You're probably due for a complete overhaul of all bushings in the rear. You should also check your axel hubs at the differential for excess play.
Old Dec 26, 2007 | 12:40 PM
Durango_Boy's Avatar
Durango_Boy
Straightening is only one piece of the problem. I would guess you have some issues with your rear suspension and the rods were bent to compensate for the worn components.
It would be a good idea to have the rear looked at by a professional if you don't know what you're looking for.
Old Dec 26, 2007 | 01:55 PM
CCrane65's Avatar
CCrane65
Sounds like I have more work cut out for me.
I hope there's someone around here who can do a four wheel alignment properly.
cc
Old Dec 26, 2007 | 02:13 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Find a shop with the latest Hunter aligner and someone who's at least somewhat competent (preferably trained) to operate it.
I'd just replace the strut rods, they're not terribly expensive.
Old Dec 26, 2007 | 03:09 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I'd replace the rods and have a look see at the rear suspension for other possible problems.
Old Dec 26, 2007 | 03:59 PM
CCrane65's Avatar
CCrane65
The only reason I can think of to bend the strut rod is to make them shorter but from looking at them, it appears that who ever bent them didn't understand how to adjust them because the adjusters are in a position to maximize the length of the strut rods if I am looking at this correctly.
The mounting holes are elongated and the strut rods are mounted as far inboard as possible with the adjusters mounted as far outboard as possible. If I wanted to shorten the strut rods, I think I'd turn the adjusters 90 degrees out so they point either straight up or straight down.
Am I right?
cc
Old Dec 26, 2007 | 04:08 PM
CCrane65's Avatar
CCrane65
Garys 68, I was not able to detect any play in the axel hubs either rotationally, inward/outward or up/down.
When I first got the car a year ago September I took it to my local Chevy dealer for a once over and the only thing they found in the rear end was a slight up/down movement in the right wheel bearing. They said it would need attention at some point but not immediately.
Since I knew that I would be spending most of the time fixing things the first year or so rather than driving it I elected to delay that particular repair.
Other than that the only thing that is obvious is the worn bushings and the bent strut rods.
cc
Old Dec 27, 2007 | 09:19 AM
carbster09's Avatar
carbster09
Default Same problem with mine ..
My car had bent strut rods when I got it. I think people don't understand how to really align the car and / or the adjusting cams get rusted / frozen up and they can't be bothered doing it the "right" way. Just stump up a little cash and go with the adjustable ones from VBP. The're great.
carbster
Old Dec 27, 2007 | 09:30 AM
Aggitated Monkey's Avatar
Aggitated Monkey
Or...Maybe Bubba placed a jack under the struts in an attempt to jack one wheel at a time. This is what happens on other cars that also have IRS.
If that is the case then you could just replace the struts have it alighned and Done.
Old Dec 27, 2007 | 09:37 AM
Garys 68's Avatar
Garys 68
Well that's good news. You may get lucky and all the stuff may have been replaced after the rods were bent.
I'm guessing it's a 72? If so the original rubber bushings would probably be going bad if they had not been replaced at some time.
Buy new rods with bushings and have them replaced at the same time you have it aligned and everything checked.
Old Dec 27, 2007 | 12:32 PM
chris73cpe's Avatar
chris73cpe
when those camber bolts rust up, they can be a real pain to get out. I managed to break off both the head and nut side of one of mine taking it apart. I was replacing them with VB+P strut rods so I didn't really care, but I can see how an alignment shop wouldn't want to touch them
Old Dec 28, 2007 | 09:24 PM
CCrane65's Avatar
CCrane65
Well, all, it looks like a weak spring is what they were trying to compensate for. I had a friend under the car to look it over and he noticed 1 inch spacers on both of the spring bolts.
Looks like I need to replace the spring too.
cc
Old Jan 2, 2008 | 01:24 PM
Garys 68's Avatar
Garys 68
Well, that's a lot cheaper and easier than an entire rear suspension rebuild.
One note, when replacing the rear spring: Do not tighten the 4 bolts that hold the spring to the car while it's on stands. The weight of the car has to be on the tire before they are completely tightened.
Old Jan 2, 2008 | 03:09 PM
jackson's Avatar
jackson
straight from my MOOG cat:
spindle support strut (aka rear strut)
EACH and is entire strut with rubber bushing installed 2 req'd/car
82-80 K6214
79-63 K6213
cam bolt kit (1 req'd/car)
82-63 K8243A
I can tell you that "eccentric" cam bolt kit is rather inexpensive & highly recommended you have on hand if you plan to take any of that stuff apart.
Old Jan 2, 2008 | 05:25 PM
Jim_Harrison's Avatar
Jim_Harrison
I think this is typical Bubba fix for older Vettes. As a metal spring gets older it starts to sag and the rear wheels get too much negative camber. The easiest way to get the camber back is too take a big hammer and bend the bars specially if all the adjustment has been taken out or the bolts are rusted. A new spring and new strut bars will fix this. This is the perfect time to go through the whole rear suspension and 0 time it.
Old Jan 2, 2008 | 05:34 PM
CCrane65's Avatar
CCrane65
Thanks guys. I plan to make sure I have experienced help on hand before I start this little venture.
I will keep all of the tips and advice in mind while we are tackling it.
cc
To Bent Strut Rods
