75 Luggage rack
Old Dec 29, 2007 | 07:05 PM
markey mark's Avatar
markey mark
Default 75 Luggage rack
Got a luggage rack for Xmas. Never plan to put any luggage on it but I think it looks good. Any hints on how to install it? Looks like the gas tank has to be dropped to get at the rear lid. I'm thinkin' about drilling the holes and siliconing the thing on, probably save a lot of time, and I'm never gonna carry anything on it anyway, just like the way it looks. I can imagine my golf clubs flyin' off on some x-way off ramp.
Markeymark
Old Dec 29, 2007 | 07:27 PM
chris75stingray's Avatar
chris75stingray
http://ecklers.com/product.asp?pf_id=46057&dept_id=173
use these. you stick them in the hole and when you tighten the bolt it expands to lock in. no need to drop the tank and please DO NOT use silicone. i know you are not bubba
Old Dec 29, 2007 | 07:51 PM
Binnie77's Avatar
Binnie77
Old Dec 29, 2007 | 08:14 PM
spike1360's Avatar
spike1360
Unless you bought it used, it probably came with well nuts which I believe someone linked you to. They're very easy to use for the luggage rack, though I don't recommend them for the side view mirrors . You just drill holes in the rear deck, making sure not to too deep and puncture the gas tank and them drop the well nuts in.
66roadster427's Avatar
66roadster427
I guess the main thing to watch is that the rack is centered but more importantly that you can get your gas cap cover opened
Old Dec 29, 2007 | 09:17 PM
ragtag74's Avatar
ragtag74
Default ragtag74
If you have a convertible, be sure to position the rack far enough back to clear the hatch cover when opened. John
Old Dec 30, 2007 | 04:53 PM
dmayhew's Avatar
dmayhew
Default another point to consider
I assume that the rack came with a template to locate the 6 holes. A 1975 car should use a 6 hole rack not a 8 hole. The 8 will filt but will not be period correct. If you received a 8 hole you may want to consider exchanging for a 6 hole.
But I have seen luggage racks that were installed a few inches forward of what I beleive was the standard location. As another member stated you want to allow for the fuel tank to open. My car is a 71 and the fuel cap door has about 3/4" gap between it and the back side of the luggage rack tube when the door is open.
Also I remove mine from time to time to wax under it. I agree no reason to remove gas tank to drill the holes or install.
Just measure several times and put some tape on the bottom of tubes. This way you can lay it on the car with out damaging the finish and test the palcement and centering and squaring off before marking holes.
The Fiberglass should drill very easily but I do suggest palcing tape around the hole marks just in case the drill slipps.
Also be sure to use proper drill bit size per the weld nuts requiremenys. They need be pushed in with a little bit of pressue. Then one you tighten the screw it will squeeze up tight and hold.
But I too agree that the luggage rack adds to the look of the car.
David
Old Dec 30, 2007 | 10:09 PM
VettePower's Avatar
VettePower
Took my rack off. I think it looked like crap to begin with. And washing, and drying the car was ridiculous. Let alone waxing it. If you don't have holes already drilled into your deck, than for god's sake forget this madness and put it up for sale on Ebay!!!!!
Old Dec 31, 2007 | 09:02 AM
dmayhew's Avatar
dmayhew
Default I hate to be roude
Man , I think postings like this are un called for on this forum. I have enjoyed this venue and have gained lots of knowledge and helped others as well. I have meet lost of great people.
As I read the gentelmans posting he seemed to like the rack he got as a present and wanted help installing it. But to refer to his gift as looking like Crap goes against the sprit of this forum.
It would be my guess that not too many family members would buy something like this as a gift for someone as a wild guess. My guess is that he asked for it or someone knew he wanted it.
I have also seen cars with the entire rear end busted and shattered and the body shops can fix them like brand new. So if that can be done the I feel pretty sure that 6 1/2" holes could be glassed over if in the future this man or anyone wants to remove their rack.
I think this is a place to offer the help asked for with cautions and just so you know type of feed back, and leave the judging of what someone else wants to do on their car out or at least leave out some of the negative wording.
David
Old Dec 31, 2007 | 11:26 AM
Binnie77's Avatar
Binnie77
David
Well said David!!!
Old Dec 31, 2007 | 11:31 AM
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
I think that Your Luggage Rack is a Wonderful Christmas Gift....given by someone who loves you Greatly....and it will not look out of place on Your Corvette....If you received it as a Kit...the Sealing Nut will pull up on the gas tank side of your fiberglass deck and distort to form a seal...so, no sealant will be required...as this New assembly will be on the outside of the Driver/Passenger compartment......
Take care, and we will see you down the Trail
Old Jan 1, 2008 | 09:20 PM
VettePower's Avatar
VettePower
David
Re-read...I said mine looked like crap. if he likes the look of it, fine. He can do anything to his car that he likes, because after all....it is his car.
Everyone is entitled to an opinion aren't they??? This is America the last time I looked.
Old Jan 1, 2008 | 11:17 PM
dmayhew's Avatar
dmayhew
Default Nice try , but you missed on the back pedal
I know you said YOURS looks like crap. No need to re read, I also was pretty sure that you had not seen the actual rack that the gentelman received. But since all racks are pretty much the same. I think your explination that this was just your openion of YOUR rack fails. The words translate a little more harshley to the mans gift that you seem to be implying by saying I WAS JUST TALKING ABOUT MINE. And you did go beyond just telling the man what you think of your rack. You suggested to him to NOT install the rack and to stop the madness.
And yes this is America , And in the America I know people keep pissy comments to them self unless they are asked for their openion.
As I recall the question was HOW DO I INSTALL?
It was not WHAT DO YOU THINK OF THE LOOK OF LUGGAGE RACKS? I GOT ONE AS A CHRISTMAS GIFT , AND SHOULD I INSTALL IT OR SELL IT ON E-BAY
I am done with this subject
Have a happy new year
David
Old Jan 2, 2008 | 05:48 PM
markey mark
I got the wellnuts with the rack but didn't really look at them until I read some of the replies. Thanks for the info. I see they're pretty much like rubber toggle bolts.
Markey mark
Ya know if I had to I would silicone that thing on and it would never ever come off. 5 minute epoxy works real well too.
Thanks again.
By the way done any engine work? I 'm lookin' to upgrade the 165h.p. It,s probably only about 125 now, it's pretty tired.
To 75 Luggage rack
