Under Dash Vacum Line Help
Old Dec 26, 2007 | 03:56 PM
abuguy's Avatar
abuguy
Default Under Dash Vacum Line Help
does anyone have a diagram of the under dash vacum line routing? previous owner ( i think his name was Bubba) made a mess of under dash wiring and vacum lines. i think i have a handle on it but one of the lines that goes to the headlight door opening switch that mounts beneath the dash has a tee inline (plugged with a trimscrew!) . should their be a tee there? any pics or diagrams would be greatly appreciated, also pics of where that switch mounts to the dash underneath.
thanks,chris
Old Dec 26, 2007 | 05:21 PM
Durango_Boy's Avatar
Durango_Boy
What year C3 do you have? For that matter, filling out your profile will help us a lot when trying to walk through a problem with you.
Here is a generic diagram but know that the later C3s had less vacuum stuff under the dash.
Old Dec 26, 2007 | 05:39 PM
jim2527's Avatar
jim2527
Unfortunately DB's diagram is incorrect. The blue hose connected to the port closest to the firewall on the headlight switch goes to port closest to the floor on the pull down switch....
Old Dec 27, 2007 | 07:25 AM
abuguy's Avatar
abuguy
Sorry for the brainfart , my car is a 77 model (and i filled out my profile!)
thanks,chris
Old Dec 27, 2007 | 08:35 AM
Durango_Boy
Hmm...seems there are more than a few wrong diagrams floating around. I didn't create it...just posted it, but I compared it to a later model vac diagram and IT'S incorrect as well based on your correction.
Old Dec 27, 2007 | 07:12 PM
jim2527's Avatar
jim2527
Thers a few of them out there. At least one vendor has an incorrect diagram in their catalog!!!
Old Dec 28, 2007 | 05:25 AM
RunningMan373's Avatar
RunningMan373
Not to highjack, but does anybody have a diagram of the heating/ac vacume routing? go a hiss coming from under the dash- '73.
Old Jun 22, 2008 | 01:30 AM
on1wheel01's Avatar
on1wheel01
Wow old thread i know,but i am wondering what is the bare minimum i would have to have to just have headlights working. I have no heat no ac.
Old Jun 22, 2008 | 06:15 AM
bvanpelt's Avatar
bvanpelt
on1wheel01:a) You need a source of vacuum to the two headlight "relays" between the headlights. b) You need a vacuum supply to the headlight override valve under the steering column, and c) a line (should already exist) going from the override valve to the headlight relays. This minimum would allow you to control the headlight doors with the override valve. If you brought vacuum to the headlight switch (should exist already) and brought the headlight switched vacuum to the ovrride valve it would work normally.
Old Jun 22, 2008 | 08:11 AM
...Roger...'s Avatar
...Roger...
Here is bare minimum.You will use the pulldown under the dash to raise and lower the headlight buckets-use your headlight switch to turn on the beams.(ignore the text saying head lamp switch at the top)
If you want the headlight switch to be included in the vacuum let me know and i will post that pic.
Old Jun 22, 2008 | 11:37 AM
GPGG70's Avatar
GPGG70
Is this a DR diagram? If so, I'll have to get me one of those.
I like it.
Old Jun 22, 2008 | 12:02 PM
on1wheel01's Avatar
on1wheel01
Thanx guys for the help.
That one seems the easiest, I just need to get a pull down switch and some air line and a new filter as mine touched a header. The car has been basterfied with wiring and air lines. I think ill hit up ebay for the parts i need. Again thanx guys
Old Jun 22, 2008 | 12:22 PM
on1wheel01's Avatar
on1wheel01
Ok for some reason I have three vac lines going to a long tube in the front,looks like a big cross bar brace all the way from pass to driver side, wtf?
Old Jun 22, 2008 | 12:40 PM
Peterbuilt's Avatar
Peterbuilt
That long tube is the vacuum tank on your 74. PG.
Old Jun 22, 2008 | 12:55 PM
on1wheel01's Avatar
on1wheel01
Well dang now as i sit and look at this digram, i thought the actuators we're the tank. Sorry new to this whole thing.
Old Jun 22, 2008 | 12:59 PM
on1wheel01's Avatar
on1wheel01
Ok anyone know where I can get a pull down switch as I don't see any on ebay
Old Jun 22, 2008 | 01:29 PM
Peterbuilt's Avatar
Peterbuilt
I get a lot of stuff from www.riksvet.com The pull down switch is part # SWT542 PG.
To Under Dash Vacum Line Help
Old Jun 22, 2008 | 01:56 PM
...Roger...
Are you sure the pulldown isnt stuffed under the dash or still mounted in the stock location?Also if you would like I can tell you how to hook it up using only the headlight switch and leaving the pull down switch out.
Old Jun 22, 2008 | 02:02 PM
bmotojoe's Avatar
bmotojoe
It is sure nice to have the manual pull switch to replace a burnt out headlamp or just to wash this area JMO.
Old Jun 22, 2008 | 02:16 PM
on1wheel01's Avatar
on1wheel01
Well under the dash is a nightmare with wires, i have no idea where the switch is suppose to be. And I am all ears to hear any thing to save mne from buying parts
