How do i get these off? struts..
Old Dec 26, 2007 | 09:01 PM
Bullcrappy1's Avatar
Bullcrappy1
Default How do i get these off? struts..
these things seem like they are one piece... book says pull towards fron of card...no moving at all...tried PB for two days.
should i heat them up? i put nuts on them then used a block of wood nothing.
the traling arms are only 3 yrs old so they had to have been off then right?
thx
rich
Old Dec 26, 2007 | 09:34 PM
Vette Gator's Avatar
Vette Gator
I built a knocking tool on the lathe - just a 1.5" piece of steel rod drilled and tapped to thread onto the shock mount. Screwed it onto the end and beat the living h*ll out of it to break the shock mount loose. Some people have used nuts from the hardware store, but be careful since it's easy to mess up the threads and then have to order a new one (don't ask me how I know this). I think that Corvette Central sells a knocking tool, but if you have access to a lathe, it's quick and easy to make one from some scrap.
Old Dec 26, 2007 | 09:47 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
if your replacing them and have access to a torch I would try heating them first. They are notorious for fusing together. Will probably still have to beat hell out of them even when hot. I've been reading up on these, I am going to take mine off this weekend and replace. Let me know if you get a solution and I will do the same. I have the torture chamber set up and ready for them. I hope...
Old Dec 26, 2007 | 09:54 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The threads don't look bad when I enlarged the picture. These suggestions can be found on our web site under the "repair help" section.
http://willcoxcorvette.com/product_i...ducts_id=24734
Old Dec 26, 2007 | 11:10 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
1) 3/8 NPT pipe cap matches the threads on the shock mount and costs about $0.80 at any hardware store. Cheap shock mount removal tool.
2) If it won't budge with the removal tool, find an oxy/acetylene torch, burn out the rubber, turn the strut rod as far sideways as you can, then get the bushing inner sleeve cherry red hot. At that point you should be able to tap the shock mount out with the removal tool.
3) Good used bearing supports are about $60, any Corvette breaker should have a pile.
Old Dec 26, 2007 | 11:24 PM
palamesa's Avatar
palamesa
I used a 2 arm gear puller. Put a small center punch dimple on the stud to keep it on center. Worked like a champ....gp
http://i187.photobucket.com/albums/x...a/DSC04128.jpg
Old Dec 27, 2007 | 09:23 AM
Aggitated Monkey's Avatar
Aggitated Monkey
With that and soaking with penetration oil should do it.
Good Luck
Old Dec 27, 2007 | 01:17 PM
wjsullivan's Avatar
wjsullivan
I bought the removal tool. That plus a 5lb hammer did the trick.
Make sure you use some anti-seeze on them when you put them back in.
Since I've already done this, if you want the knock out tool let me know. Send me a PM and we can work something out.
Old Dec 29, 2007 | 12:30 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I did mine last nite, had soaked them down with Moovit, then put the 2 arm puller on them and they slid right out.
Old Dec 30, 2007 | 02:31 PM
Jack71's Avatar
Jack71
Use heat. It will pop right outta there when its red hot.
Two things to keep in mind...
1) have a friend watch for fires (better to be safe)
2) don't touch the mount after it pops out for a few minutes
Old Dec 30, 2007 | 03:03 PM
Paul L's Avatar
Paul L
What is the purpose of the splines on the shock bolt shaft?
Old Dec 30, 2007 | 07:35 PM
Jack71's Avatar
Jack71
It gets pulled into the housing when you tighten the nut. I presume to create a nice tight fit -- thus creating all of these posts!
Old Dec 30, 2007 | 11:41 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Old Jan 1, 2008 | 08:48 AM
koni9's Avatar
koni9
Torch all the way..... Splines are for anti-rotation, also for a snug and secure fit.
Old Jan 2, 2008 | 11:17 AM
Darrel1's Avatar
Darrel1
I just removed mine this weekend. One trick I did is I wrap tin foil around the bottom of the area and made a cup. I sprayed PB blaster in the foil and so my brackets were able to be submerged overnight. I then heated them up with (not red- just hot) and then popped them out with a hammer and metal rod (smaller than the diameter of the bracket.
Darrel1
To How do i get these off? struts..
