Jet Performance Quadrajet
Old Dec 28, 2007 | 10:17 PM
derv3tt3's Avatar
derv3tt3
Default Jet Performance Quadrajet
Does anyone run a Jet stage 2 quadrajet?I would like to tune my carb to Lars tuning paper,but hate to take the top of carb off just to see what primary jets and rods I have to start with.
Old Dec 29, 2007 | 04:09 PM
lars's Avatar
lars
You have to take the top off the carb to check jet/rod sizes. The jet sizes in somebody else's carb won't tell you anything about yours since JET jets their carbs based on the carb number, and they use a lot of different carb number cores in their carbs.
Old Dec 29, 2007 | 06:53 PM
VRGSVET's Avatar
VRGSVET
Default Quadrajet on ZZ4?
I am also planning to try my hand at tuning my Quadrajet, but first I am planning to swap out my tired old L48 for a ZZ4 Crate motor.
Does anyone have any suggestions on what jets and rods I should start with if I bolt my Q-jet on the ZZ4? I have a stock 1980 L48. I want to be able to put my stock carb on the crate engine, get it started and running decent right off the bat so I can get the break-in period done. Then I'll go back and tune it according to Lars' procedures.
Old Dec 29, 2007 | 07:30 PM
TopGunn's Avatar
TopGunn
If it was performing good wth your present motor you can mount it on the ZZ4 and it'll fire right up without any issues. It'll be fine.
Old Dec 29, 2007 | 07:48 PM
VRGSVET's Avatar
VRGSVET
Thanks for the reply. I see you're running a ZZ4; what carb are you using? How do you like you're headers? I'm still shopping for headers.
Old Dec 29, 2007 | 08:20 PM
TopGunn's Avatar
TopGunn
I'm using a Q-jet, I bought a 77 carb and modified the idle circuit so it runs a little better. I have FlowTech ceramic coated headers, they bolted right up no problem at all. Your Q-Jet should be just fine with the ZZ4, you can fool with it a little later on after you get everything else you encounter dialed in.
Old Dec 30, 2007 | 07:24 PM
derv3tt3's Avatar
derv3tt3
Lars what car did this carb # fit 17059507 ?
Old Dec 30, 2007 | 10:08 PM
lars's Avatar
lars
The number would indicate that it's a 1979 California truck carb, but my 1980 Rochester parts book does not show the 17059507 number as valid - it goes from 17059506 to 17059508 with no 507. It's possible that it's a service replacement carb for a '79 truck carb built after 1980. Henry has the later Rochester books and can check to see if that's the case if he sees this post.
Lars
Old Dec 31, 2007 | 02:10 PM
derv3tt3's Avatar
derv3tt3
Thanks for trying.
Old Dec 31, 2007 | 03:32 PM
olescarb's Avatar
olescarb
17059507 is from a 79 chevy p/u truck (350?) with california emmisions, this # is not listed in the parts portion of the rochester "C" carburetor manual but it was a OEM carburetor in Calif.
I hope this helps Henry @ olescarb
Old Dec 31, 2007 | 08:24 PM
derv3tt3's Avatar
derv3tt3
Thanks again
To Jet Performance Quadrajet
