zz502 fit??
Old Dec 29, 2007 | 05:56 AM
agent kronus's Avatar
agent kronus
Default zz502 fit??
does the bb zz502 just drop into a 78 vette, or do you need to change engine mounting brackets on chassis, also is there anything in the engine bay that will foul the engine?, also I take it the th350 gearbox etc, will fit straight on??
also any other things to look out for with this change??
cheers
dave
Old Dec 29, 2007 | 11:31 AM
rihwoods's Avatar
rihwoods
cheers
dave
This one is in my 69 Coupe...Your biggest issue will be hood clearance...mine has a L88 aftermarket hood...(4 speed tranny..)
A 502 will fit in a 78...no problem..
Old Dec 29, 2007 | 12:07 PM
roscobbc's Avatar
roscobbc
cheers
dave
You should have posted this on CCCUK Dave! Got a buddy thinking of doing the same thing. Wouldn't it be easier to get a stroker kit for your 350 or get a stroker crate engine?
Old Dec 29, 2007 | 01:08 PM
Dantana's Avatar
Dantana
That's a beautiful 502
Makes me wonder if I should scrap my 427 plan and go for the cubes
Old Dec 29, 2007 | 01:19 PM
agent kronus
I will do that, not sure what to do just weighing up the options, one good think about the 502 is the level of power you can get from it must be higher than a 350 stroker??
agent kronus
thanks for info so far guys
dave
Old Dec 29, 2007 | 01:36 PM
rihwoods's Avatar
rihwoods
Thanks !!
A complete ZZ502/502 (Carb to pan) is around $7,000...it also weighs less than a cast iron head 427...
I have 28,014 miles on the engine with no issues...
Old Dec 29, 2007 | 02:15 PM
panic's Avatar
panic
Originally Posted by rihwoods
Thanks !!
What's the power output, and at what rpm level?
Old Dec 29, 2007 | 02:55 PM
wesleyshawn's Avatar
wesleyshawn
cheers
dave
you may want to reconsider bolting that 502 to your present th350 tranny, if that is your plan. Depending on how you drive the tranny might not hold up very well.
Old Dec 29, 2007 | 03:11 PM
rihwoods's Avatar
rihwoods
At Crank: 502 HP @ 5200 rpm...567 LB/FT Torque @ 4200p rpm....
Max RPM:5800
Est: 410 RWHP....460 RWTQ
I'm running a 4 speed Muncie and 3.70 gears...
Rich
Old Dec 29, 2007 | 04:43 PM
agent kronus
this is the whole problem, what to go for, sb 383, 427? or bb 502 etc??
whats the best option, i just dont know what to go for, one thing is for sure I want a good 500bhp engine.
dave
Old Dec 29, 2007 | 06:00 PM
wesleyshawn
dave
why not go with the 502 and change the tranny as well?
Old Dec 29, 2007 | 06:11 PM
bruced267's Avatar
bruced267
Just remember this " There is no replacement for displaclement" !! and Im not a fan of the bigger is better theory. However I have purchased and built toys and felt the need for more engine!!!!
Old Dec 29, 2007 | 11:33 PM
rihwoods's Avatar
rihwoods
dave
What ever you chose be sure to put the the right emphasis on rear gears...
Old Dec 29, 2007 | 11:51 PM
FRSTR90's Avatar
FRSTR90
Thats what TH400's are for!
Old Dec 30, 2007 | 11:53 AM
stingr69's Avatar
stingr69
Maybe someone here will comment on the acessory brackets and pulley requirements from someone who has been through the swap already. GM sells a full acessory mounting kit but it might not be the best way to accomplish the C3 sb to bb swap. Anybody been there - done that?
-Mark.
Old Dec 30, 2007 | 01:17 PM
rihwoods's Avatar
rihwoods
-Mark.
My 502...no A/C...
I purchased some brackets at Zip....
Rich
To zz502 fit??
Old Dec 30, 2007 | 03:50 PM
stingr69's Avatar
stingr69
My 502...no A/C...
Rich
Rich,
That's good to know that you can get all of the pieces required for the swap. It looks soo tempting.
-Mark.
Old Dec 30, 2007 | 06:48 PM
roscobbc's Avatar
roscobbc
dave
Dave, I have 427 manual (not quick enough), I am having a fresh stroker 496 built-up shortly, this will be costing me in the region of £7.5K+ all in for (if I'm lucky 550/580 hp) You can get your small block engine' stroked' with perhaps a 450/525 hp built-up in UK for perhaps a grand less than that (or even less from 'States) - no essential gearbox changes - or spring changes - or drive shaft changes - bolt straight in with perhaps a torque converter change? Remember it ain't HP that does the job but TORQUE!
Old Dec 30, 2007 | 07:59 PM
agent kronus
that sounds like a beast your building there! nice
the going rate for a zz383(425bhp) long block, is about 5000$, =£2500 + tax/shipping comes out around £3500, just need a intake, carb and water pump, I just brought a rpm airgap and a holley 750 vac sec
so this does seem like, the cheapest way for more power
also the zz383 comes with a mild cam so they claim, so still room for improvement
cheers
dave
