Help with A-Arm Installation
Old Dec 29, 2007 | 10:57 PM
gr8t73's Avatar
gr8t73
Default Help with A-Arm Installation
I removed my A-arms and had a shop install new bushings. Easy to figure which the right and left hand side for lower arms but how can I tell which is the left and right side for the upper arms?
Old Dec 30, 2007 | 08:55 AM
69small block's Avatar
69small block
I have assembly manual will ck and look at Uppers for you let me know you can email me on .P.M. if you like
George
69small block
Old Dec 30, 2007 | 09:15 AM
SIXFOOTER's Avatar
SIXFOOTER
Upper control arms the Short side goes to the rear
Old Dec 30, 2007 | 10:14 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
What did the shop charge to R & R the bushings?
Old Dec 30, 2007 | 08:16 PM
gr8t73's Avatar
gr8t73
$20.00 per A-Arm or $80.00 for all four. I supplied the bushings.
Old Dec 30, 2007 | 08:19 PM
gr8t73's Avatar
gr8t73
Maybe I just didn't look close enough but I didn't not notice one side being shorter. I'll check tomorrow. Thanks I really appreciate the information.
Old Dec 30, 2007 | 11:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Neither upper or lower a-arms are an equilateral triangle. The "long" forward legs go to the front.
Old Dec 31, 2007 | 01:09 AM
C3KILLER's Avatar
C3KILLER
I don't mean to threadjack, but if you wanted to do those bushings yourself in the future, I just did mine and it wasn't that hard at all.
I put the bushings and the rods in the deep freeze overnight.
Pulled one set of bushings with the rod out at a time.
Light coat of white lithium grease and a socket, and smacked them right in! No damage to the arms, after you have the first one in, flip it over, realign the socket to the other bushing, smack that one down and your set!!
Out of a precaution of bending the a arm I did cut a length of pipe and put it in between the two a arm ends. Very easy job to do yourself, I was very nervous. I was working with brand new bushings, and freshly powder coated arms! Good luck!
Old Dec 31, 2007 | 07:44 AM
69small block
Default A arm
I removed my A-arms and had a shop install new bushings.* Easy to figure which the right and left hand side for lower arms but how can I tell which is the left and right side for the upper arms?
did you get my email
Old Dec 31, 2007 | 07:53 AM
Jud Chapin's Avatar
Jud Chapin
Thanks for the info. Not a bad price considering the amount of time you'd have spent doing them yourself.
Old Dec 31, 2007 | 07:06 PM
The3's Avatar
The3
The shop I checked with wanted $15 per bushing. For that price I went ahead and bought a Harbor Frieght press and did it myself.
Old Dec 31, 2007 | 08:01 PM
Jud Chapin's Avatar
Jud Chapin
Have a model #? And how did the job go?
Old Dec 31, 2007 | 08:29 PM
The3's Avatar
The3
It was the 12 ton press in the link below. The job was not too difficult but I would recruit a friend for the afternoon. You will also need to cut some pipe to place between the control arm slots/spaces so you don't bend or crush them when using the press.
http://www.harborfreight.com/cpi/cta...emnumber=33497
Depending on your patience, it may be better if you pay to have a shop install the bushings. There is some work involved that may leave you saying, "I should have paid to have these installed.".
It was worth it to me since I am going to rebuild my rear end. It's a good tool to have around if you work on cars.
Old Dec 31, 2007 | 09:24 PM
crf311's Avatar
crf311
Pep boys has the 12 ton press on sale right now for $49.00 after rebate.
Old Jan 1, 2008 | 07:36 PM
gr8t73's Avatar
gr8t73
Default Got It
George
Got your email and I appreciate the information. I plan to reinstall the a-arms tomorrow and thanks to the information provided I know they will be installed correctly. I love this forum it's saved me a lot of time and grief over the past few years.
Old Jan 1, 2008 | 07:37 PM
gr8t73's Avatar
gr8t73
Default Got It
George
Old Jan 1, 2008 | 09:04 PM
69small block
glad to help
To Help with A-Arm Installation
