fuel pump push rod
Old Jan 1, 2008 | 02:17 PM
69vettester's Avatar
69vettester
Originally Posted by weimer20
A different alloy is used for roller cams. Some need dist gears changed to be compatible. I've heard of fuel pump pushrods also having to be changed. I believe some have a roller tip, some have a different alloy at the tip. The thing is all about different hardness I believe. Most rollers cams now have the iron dist gear pressed on so its no longer an issue there but I don't know about the fuel pump lobe. My understanding is if this is not taken into consideration, the parts will begin to eat each other up. I have yet to use a roller cam. Sooo, I'm sure there are many here that can better confirm or deny what I've read and heard. I'll be going roller with my next build so I'll be researching all of that then.
I put a light weight Fuel pump Rod with a Bronze tip in when I went to a Roller Cam engine, in retrospect I realized I didnt have too. Hyd. Roller Cams now days Are Manufactured from Materials compatible With stock dist. Gears and Fuel Pump Rods. I think only the Racing Cams, Solid and roller still require Bronze or Composite Dist. Gears and special Fuel pump rod.
All new Aftermarket Distributors Come with Gears that Can be used with New Hyd. Roller Street Cams. They are Melonized or similar metal treatment.
PS..If Im off with any of my info, Chime in, I know this subject is Frequently and sometimes Hotly debated.
Old Jan 1, 2008 | 02:58 PM
TopGunn's Avatar
TopGunn
GM Performance told me that's not true. I had the same concerns when switching from the L48 to the ZZ4 and called GM about what rod to use with this roller cam. They told me the original rod is exactly the same as a rod they would sell for that motor. I do see advertisements by Comp Cams for special rods, maybe it's a marketing ploy, I'm not sure.
Old Jan 1, 2008 | 03:39 PM
Belgian1979vette's Avatar
Belgian1979vette
Depends on what material the cam is made of. If it is a billet steel, then you will certainly have to use a rod with messing end. If not the lobe of the cam will destroy itself.
It's one of those things that I don't like about roller cams, since it will mushroom the messing end, making it difficult to get it out once it needs changing.
I plan on using an electric fuel pump to bypass the problem.
For the rest I already have a Crane cam with a pressed on iron gear that is compatible with the iron gears of regular dizzy's.
Old Jan 1, 2008 | 04:04 PM
Edzred72's Avatar
Edzred72
Crower tech said billet core cams need the bronze tip fuel push rod. Cast steel core cams can use any fuel push rod.
Eddie
Old Jan 1, 2008 | 08:01 PM
TopGunn's Avatar
TopGunn
Eddie
Ah OK, that's probably why the different answers people get. It depends on the cam material.
Good info..thanks
Old Jan 1, 2008 | 09:01 PM
FB007's Avatar
FB007
Originally Posted by 66roadster427
They may also have it hanging in the HELP section and that part# is 03875 for about $5.
I bet that's top notch.
Old Jan 2, 2008 | 07:32 PM
Stroker-427's Avatar
Stroker-427
Check the specs of your cam...... it must be evident if you have to utilize bronze distributor gear or/and bronze tipped pump pushrod.
There is cams (like the Crane I have) with iron gear planted in the steel core (a roller cam MUST be in steel due to the very high pressure contact with the roller tip of the lifter) still needing bronze tipo for the pushrod....
The cam manufacturer must give that kind of infos!
