fuel pump push rod
Old Dec 30, 2007 | 10:20 AM
RogieStone's Avatar
RogieStone
Default fuel pump push rod
with a motor installed and timing chain cover on can you install a fuel pump push rod
Old Dec 30, 2007 | 10:22 AM
Durango_Boy's Avatar
Durango_Boy
Yes, there is a bolt hole with a short bolt in the front of the block on the front of the fuel pump location, which goes in pointing to the back of the fuel pump location toward the cam.. Remove that short bolt, and install a long bolt to hold the push rod up as you guide the pump in and over the cam. Then remove the long bolt and install the short one again.
Old Dec 30, 2007 | 10:25 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Sure, remove the fuel pump & just push it in. There may or not be a bolt in the front of the block to tighten down on the rod & keep it from slipping out. That bolt needs to be loose for normal operation (if present).
D@mn it Jim, DB beat me to the answer again!
Old Dec 30, 2007 | 10:36 AM
RogieStone's Avatar
RogieStone
I don't have a rod . I was planing on using a electric fuel pump but I changed my mind and need to install the push rod
Old Dec 30, 2007 | 11:13 AM
66roadster427's Avatar
66roadster427
you can get the push rod at oreilly's (part# pr936) for $12 or the Zone (pt# fp936) for $15. they might have it on the shelf otherwise if you order it in the morning they will have it in by afternoon. They may also have it hanging in the HELP section and that part# is 03875 for about $5.
If you have already put the fuel pump plate on (the one held on by the two small bolts at the bottom) that goes between the block and the fuel pump, you will need to remove this to get the pushrod in.
hope this helps.
Old Dec 30, 2007 | 12:49 PM
weimer20's Avatar
weimer20
Also, if you used a roller cam, make sure the parts are compatible.
Old Dec 30, 2007 | 05:05 PM
ENG40's Avatar
ENG40
What's the difference?
Old Dec 30, 2007 | 05:16 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
If you look at the bottom of the fuel pump mounting boss, there will be a pipe plug screwed in there. Take that plug out and slide the rod up into the block and replace the plug. Look at the front of the block, there is a short bolt screwed into the face, remove it. Use a long bolt to TEMPORARILY hold the rod in place after you push it up with your finger. Install the fuel pump, if you are feeling interference and the fuel pump bolts won't line up, turn the motor over by hand until you are on the base circle of the cam. Bolt the pump up. Remove the long bolt and replace it with the small bolt with sealer on the threads. If you don't seal it, it leaks oil.
Old Dec 30, 2007 | 05:52 PM
lars's Avatar
lars
The big blocks use the pipe plug. The small blocks don't have it. On a small block, just remove the fuel pump adapter plate and the rod slides right in. If you put a little grease on the rod it will stay up without using the long bolt trick. Here's another little trick: Put the engine on top dead center compression stroke on #1 cylinder. This will fully retract the pushrod (allow it to go all the way "up") and it makes pump installation much easier.
Old Dec 30, 2007 | 07:39 PM
Durango_Boy
Some roller cams do not have a mechanical fuel pump lobe. If you miss that and install the cam and mechanical pump the rod will never move and the pump will not pump and you won't understand why you're not getting any fuel past the pump.
Old Dec 30, 2007 | 10:36 PM
ENG40's Avatar
ENG40
I had to rotate my engine to get it off the high lobe so I should be good to go. Never gave it a thought that there may not be lobe for the pushrod.
Old Dec 31, 2007 | 05:37 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
That's exactly how I did mine. This method works great.
Old Dec 31, 2007 | 08:37 AM
Edzred72's Avatar
Edzred72
Blob-O-Grease worked for me too...numerous times
Eddie
Old Dec 31, 2007 | 08:48 AM
bj1k's Avatar
bj1k
He's talking about installing the rod itself. Apparently it is missing.
Old Dec 31, 2007 | 09:03 AM
comp's Avatar
comp
anybody use the light weight rod ????
Old Dec 31, 2007 | 09:14 AM
SIXFOOTER's Avatar
SIXFOOTER
never knew there was a need for a light weight rod
Old Dec 31, 2007 | 09:19 AM
comp's Avatar
comp
high RPM'S
To fuel pump push rod
Old Dec 31, 2007 | 12:52 PM
weimer20's Avatar
weimer20
A different alloy is used for roller cams. Some need dist gears changed to be compatible. I've heard of fuel pump pushrods also having to be changed. I believe some have a roller tip, some have a different alloy at the tip. The thing is all about different hardness I believe. Most rollers cams now have the iron dist gear pressed on so its no longer an issue there but I don't know about the fuel pump lobe. My understanding is if this is not taken into consideration, the parts will begin to eat each other up. I have yet to use a roller cam. Sooo, I'm sure there are many here that can better confirm or deny what I've read and heard. I'll be going roller with my next build so I'll be researching all of that then.
Old Dec 31, 2007 | 10:31 PM
Mosse57's Avatar
Mosse57
Timely subject here guys!
Would anyone know what to use to remove that plug from a big block to install the fuel pump rod?
My GMPP ZZ454 has a plug with an internal square, a 3/8s drive is to big!
For the record I'll be using the ARP fuel pump rod.
Old Jan 1, 2008 | 01:17 PM
blue427's Avatar
blue427
could this be used to determine #1 firing order if distributer is out of car.In anotherwords if balancer is on "0" and your on #6 compression stock would your fuel rod be at a different height?
