75 l48 engine and head question
I have a 75 L48 and was wondering , is this a 4 or 2 bolt main and also what size valves are in the heads? Going to do an engine rebuild to keep the car numbers matching. Thinking about some head work and a mild cam. Not looking for a lot of H/P, just something thats fresh and a little pep in the mid range for cruising the 4 lane when needed.Thanks,
Gary
heads are a much easier way to get hp....
numbers matching includes heads..... does it include dish pistons? hehehehe
Honestly, I think a crate motor in bumper cars is a bit of a waste, especially if you're just looking for a modest improvement. These cars aren't worth a whole lot in prestine condition, so keeping your car #'s matching seems to be a bit rediculous.
As far as valve size, the stock L-48s were 1.94"/1.50"
There's unfortunately no way to tell the main cap type from the outside, but a 2-bolt block is fine for the power levels you're building to. Shoot for around 9.5 CR.
The head is most likely #333881 (casting mark like a right triangle) with 2.02/1.60 valves and a 76cc chamber - not a great head by any means (and a new aftermarket would be better in every way and likely cheaper) but with a little bowl clean-up and a good valve job they're good for your power level. Go ahead and invest in screw-in studs and valve springs to match your cam; I wouldn't bother with roller-tip rockers but just a good set of new Crane rockers, sticking with the 1.5 ratio.
One of the CompCams High Energy series is fine for your build; avoid going to an extreme cam if you're sticking with the stock intake and not using headers. While I'd still want your gearing, I'd suggest the 260H if you're sticking with stock intake/exhaust, and maybe the 268H if you're using either and/or both.
It'll be really easy to overbuild; keep your targets in sight
Finally, I agree with prior posters that more power is available for less money in a crate or other engine - but there's nothing wrong with doing a good performance overhaul on your original engine.
Definitely check your rear gear, and what tranny do you have? What kind of HP numbers are you raelly looking for?
During a rebuild, any piston can be selected - definitely agree that if it's just a top there really aren't any options it takes about a .006 mill to pick up 1 cc, and 10cc to make 1 point of CR difference. I read this as a completely overhaul - if that's a mistaken impression then the situation is definitely different regarding CR!
The 260H is as far as I would go for a cam, the rest of the information is valid.
THANKS for catching!
You'll definitely be happy with a crate with those gears - no reason you can't paint it the right color and make it look "factory" in every way
There are a bunch of crate engine options, but IMHO the best "bang for the buck" in the market today is the GMPP 350/330 (P/N 12486041) - but there are many choices out there, so once you have a budget established you'll have lots of options.
