Performance intake for Q-jet (a bit long)
But now my intake is not making it!!! It's a performer vortec just a bit better than the stock one. I had no choice because of the hood clearance with the stock air cleaner assembly that I want to keep (stock look).
My car is a summer daily driver and I love taking long trip with it as going to the strip. So my Q-jet is the best carb to do that with an average of 20 mpg on the higway.
I searched without luck for an intake that could flow more with my vortec heads and Q-jet. In fact, you can't have an intake better than the performer (base not rpm) with a Q-jet on a small chevy. It looks like that a Q-jet is not a performance carb.
(After seeing my friend cutlass 68 with a 455 doing 11 flat on the quarter with a Q-jet, I got convince otherwise.)So here my plan, I bought an Edelbrock Super Victor for vortec head, gonna cut the carb pad about 3/4 of an inch and fit the Q-jet on top. That should clear the hood with the stock air-filter a bit cutted.
Anybody done that? I'm a bit worried about cutting a brand new intake!!!
Here some pics of the plan...
Stephan
You seem to be on the fence with your goals in keeping mileage/cruising as well as peak top power.It is next to impossible to have both without overdrive trannies,and fuel injection.
But I guess we'll see when the cuting is made.
Stephan
The super victor has been tested in Chevy High performance mag with vortec heads and have given something like 15 hp over the performer RPM intake. All that under 6000 rpm. I give you that the victor jr would have been a better choice for my engine but there not available for vortec heads so the machining would have been extensive.
Keeping it daily streetable with maximum top end is the real challenge.
Too bad you are using the Vortec heads or I would have suggested a Performer RPM Q-Jet. It is working well for me.
Bee Jay
They where designed for the 350" sb motor and higher rpm while very steetble. And it will clear the hood too.
Unless u have a really large cam (>280* duration) and can spin past 6,500rpm i don't think the Super Victor is gonn'a work - Victor Junoir maybe.I picked one (Holley/Duntov single plane) up at a swapmeet for pocket change but the studs where bad and need fix.
BTW most dedicated racers will add a 2" spacer to that Super Victor intake. Personally i think cutting up a band new Super Victor will ruin it and have no resale value either.
But u may have done more research and know it will work on your combo so good luck to you.
cardo0
Some welding, cutting and machining will be necessary to fit the carb and I'll wait at the end to position the carb on top of the intake.
I really liked the Performer RPM on another engine I had. I wouldn't have hesitate if I could have use it.
Bee Jay
Good luck with the fuel injection. It should be a nice setup.Stephan
cardo0
A big single plane will shave some torque but my engine is producing a lot of it between 2000 rpm and 4000 rpm and with my 3.73 rear gear, it won't be too much of a problem. It's a sacrifice to gain (I hope so) something 20 to 30 hp at the top.
Stephan
I could have bought a Professional Product to save 50 bucks but my machinist told me to stay away from them since the quality of the aluminium is poor. So is the finish.
Stephan
