Ignition replacement on 81 Vette
Old Jan 1, 2008 | 12:26 AM
bolinjones2002's Avatar
bolinjones2002
Default Ignition replacement on 81 Vette
Help, I did the unpardonable... I misplaced my ignition & door keys on my 81 Vette. I just got a new ignition switch w/keys & new door locks w/keys from Mid-America Corvette. I need help replacing the ignition switch. Thanks guys, Bob J Happy New Year while you're at it.
Old Jan 1, 2008 | 10:07 AM
SIXFOOTER's Avatar
SIXFOOTER
Your not going to like this.
Remove the steering wheel
Pemove the turn signal switch just enough to get it oveer the steering shaft.
Remove the screw that passes thru the lock cylindar.
Put the lock cylindar in RUN and pull it out
Reverse for reassembly.
That sounds deceptively simple, watch for broken plastic parts
Old Jan 1, 2008 | 11:36 AM
Jim Shea's Avatar
Jim Shea
Here are some fairly complete instructions on replacing your ignition lock cylinder. Go to the following websight address:
http://jimshea.corvettefaq.com/?page_id=4
Scroll down and download the following two papers in the Tilt & Telescoping Column section:
Tilt & Telescoping Column 69-82 Disassembly & Repair Paper #1 (Rev 09OC07) - check for loose pivot pins, support screws, & lock shoes, replace lock cylinder, key buzzer, turn signal lever, and adjust telescope lock Link
Tilt & Telescoping Column 69-82 Disassembly & Repair Pics #1 - Used with Papers #1, #2, #3 (Rev 12FE06) Link
BTW, the ignition switch on your T&T column is mounted on top of the steering column down under the dash. Your ignition lock cylinder is located in the steering column head and it is the part where you insert your ignition key.
Jim Shea
Old Jan 1, 2008 | 05:02 PM
bolinjones2002
Hey Guy
Happy New Year and thanks for your most informative reply.
I needed that. Much Obliged. Bob J
Old Jan 1, 2008 | 05:07 PM
bolinjones2002
Happy New Year Six Footer!
Your response reduces my needs down to a manageable size. Thanks loads for the info on the ignition switch. Bob J
To Ignition replacement on 81 Vette
