best way to remove steering coupler?
Old Jan 2, 2008 | 11:18 AM
la80vette's Avatar
la80vette
Default best way to remove steering coupler?
I have an 80' that I am prepping for a body lift. Can anyone give advice on the best way to remove the steering coupler? Does the the column have to be removed or moved?
Thanks,
Stephen
Old Jan 2, 2008 | 11:43 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Loosen the two clamp bolts on the coupler, remove the bolts holding the steering column in place, then try to slide the column back. You might have to use a screwdriver or small prybar to get the coupler to let go.
Old Jan 2, 2008 | 11:45 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
I loosened the the two collar clamps and the bolts holding the coupler and pried them apart, gently.
Jim Shea's Avatar
Jim Shea
Either the column has to be moved back into the driver compartment by about 2 inches or the gear mounting bolts have to be removed so that the gear can be tipped to make room for the flex coupling to be removed from the gear shaft.
I don't suggest prying on the flex coupling because you might collapse the steering column shaft back into the steering column. The steering column shaft can be a devil to get back out to its original length.
Jim
Old Jan 2, 2008 | 12:24 PM
GTR1999's Avatar
GTR1999
Jim
Follow Jim's advice. You will not even know you collapsed the column until you go to put the rag back and it doesn't fit flat. Mark the column at the firewall with chaulk and you'll be able to see if it moves back on you.
Old Jan 2, 2008 | 01:02 PM
la80vette's Avatar
la80vette
Thans for the advice. Hope to have that body off soon.
Stephen
Old Jan 2, 2008 | 04:15 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Jim
I should clarify...I was talking about prying parallel to the clamp bolt in order to spread the "ears" of the coupler - not prying against the steering column. In my experience, the metal of the coupler flange sometimes "sets" in place and needs some persuasion to let go of the steering column splines.
Old Jan 2, 2008 | 04:32 PM
dobroman2001's Avatar
dobroman2001
Thanks,
Stephen
Here's some pics that show the column being removed.... FYI, it may help.
http://s189.photobucket.com/albums/z...man2001_photo/
Old Jan 2, 2008 | 05:22 PM
la80vette's Avatar
la80vette
Thanks for the photos. I think I'm going to pull the column out now. The whole thing isn't even secured. The column moves from side to side. I think the mount may be broken.
Thanks,
Stephen
To best way to remove steering coupler?
